Engine build crankshaft help
ThreeQuarterTon
Apr 25, 2016
Long story short, bought a block, crank and cam from a guy who had a handful of motors pulled from lb7-lbz and parted. Picked out the best of the cranks from his pile. Problem now is, I realized after the fact, depending on what year crank you have depends what balancer to order for my build. Now I’m aware this is for balancing Purposes of the rotating assembly. Markings on the cranks appear to have no rhyme or reason indicating what engine RPO it came out of. Is there a way to identify the differences? Or better yet, since the rotating assembly will be getting balanced anyway, does it even matter which balancer I order? For example if I were to order an lly balancer but crank turns out to be from an lbz, Will this cause issues getting the dang thing balanced? Not bad for a first post ay :D
8,050
Get the lbz flexplate and damper. Would rather remove weight then add.
should be other way round. when GM pulled piston weight for the LBZ, they added it back in at the flywheel/balancer instead of taking it off the crank.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
When I bought my crank and damper from socal they said lbz on both. Had to remove some weight.
ThreeQuarterTon
Apr 25, 2016
So then I’ll buy SoCals lbz flexate and ATI lbz damper is what I’m understanding from everyone? Or other way around and get the lly
8,050
^^this. Guy is the one who showed me the difference between factory balancers/flex plates and why they added weight to the later models.
