Best DD Engine Build??
lesrrt
03 LB7
Dec 1, 2018
13
PortDeposit , MD
I am new here, nice read for sure. Has anyone experimented with the 7.1L rotating assembly? Is So cal the only distributor of this? Are the gains worth the costs pertaining to a stout DD:thumb:
4,849
1,895
7.1L is overkill for a DD. Awesome setup but for 800ho it’s way overkill.
4,849
1,895
Any of you smart cookies willing to post your ideal (realistic/budget friendly/minimalistic) “recipe” for a reliable 600-800rwhp build like this with your choice of parts & rough prices for each...
Pistons:
Rods:
Cam:
Crank:
Heads:
Fuel:
Air:
Bearings:
Gaskets:
Machining tolerances:
Other:
Pistons: Mahle Race Cast or Delipped LB7/LLY (relief if doing cam)
Rods: Carrillo
Cam: Stock or if funds allow SoCal 6480AF
Crank: Stock that is polished and checked for cracks
Balancer: Fluidampr
Heads: Stock that are cleaned/decked/pressure checked/valve job done with upgraded springs and pushrods
Fuel: 100% over
Air: 64VGT/S480, S364/S480, or a S476/87/1.10 T4 single
Bearings: Clevite H
Gaskets: Victor Reinz Wave Stopper head gaskets and Mahle/Clevite everywhere else
Other: ARP everywhere (head studs, main studs, rocker bolts,flexplate bolts, balancer bolt), billet flexplate, billet injector hold downs
4,849
1,895
I have been thinking about CP/Carrillo Hybrids setup, but also the fact that here isn't a lot of options for cast pistons.
I love my CP-Carrillo hybrid rotating assy. Builds torque like crazy, helps the crank live by pulling 4lb out of the rotating assy, and spools a turbo insanely well (partially due to cam and big fuel).
4,849
1,895
id like to see the Diamond forged pistons in a DD engine. they have a steel ring land in them.
Forged will be noisy till warm up though as their piston to wall clearance has to be pretty large to accommodate for growth.
IIRC my CP-Carrillo forged pistons only called for ~0.008 PTW and are not noisy when cold.
Duramaxjon
Dec 12, 2016
Illinois
Pistons: 16:1 cast Fingers oval bowls $2,160
Rods: SoCal budget rods $1,700
Cam: SoCal 3388af (no valve reliefs necessary, saves on cost) $1,100
Crank: LB7 crank
Heads: SoCal stage 1 $2,200 (includes valve springs)
Gaskets: Mahle upper and lower engine gasket sets $375
Other: SoCal billet main caps $800
ARP main studs $235
PPE oil pan $280
ARP 2000 head studs $593
Thermal top coating on pistons $400
Weight match pistons $60
New LML oil cooler $377
New plastic impeller water pump $300
SoCal rocker shaft studs $109
SoCal push rods $323
SoCal billet flexplate $690
SoCal damper $457
Melling oil pump $192
ARP flex plate bolts $74
New thermostats $72
2 sets thrust washers for SoCal main caps $58
Key oil pump
Balance rotating assembly $300
Sent from my SM-N950U using Tapatalk
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
Well, after making 770HP on Marks Dyno, I guess its time to start pulling parts together for a new engine to install this coming winter. Current plan is to reuse my current heads, headstuds, and fuel system. If the current engine hasn't blown up by then, I will have a spare short block for something else.
My current build plan is
SoCal Budget Rods
Mahle Race cast pistons
Stock LB7 keyed Cam and Crank
LB7 Block with No Limit Billet Main Caps and ARP main studs
Stock head, maybe with some port work, valve springs, and pushrods
ATI/Socal Damper
ATS billet Flexplate
4,849
1,895
SoCal Budget Rods
ATI/Socal Damper
Looks like a solid build! Any reason to go with No Limit and ATS over SoCal? The No Limit main caps are great quality as well. I've never used an ATS billet flexplate but they appear to be more expensive. The ATS is $745 new whereas SoCal is $690 (unless you found one used).
MAXX IT OUT
Neglected
Mar 1, 2013
1,791
Des Moines, Iowa
The no limit caps came with my spare block and the ATS flex plate is the one on my truck currently for their 12 bolt converter, trying to save money and use parts I have laying around at the same time.
4,849
1,895
I would do the same, just wanted to ask is all haha.
Sounds like it'll be a good build. You'd be surprised how much a cam will wake it up.
