Best DD Engine Build??
paint94979
Beer Nazi
Sep 18, 2006
11,742
33
actually you would be very surprised what the cummins guys do to get them down there. sled pullers especially. i was talking to one of the pullers there (cant remember his name) but he injects so much water than EGTs never surpass 1200 but its about 3 gal worth of water poured in it by the end of the track.
we dont see over 1500* on the small tune in ours but that is a very good flowing head and big turbos. Curious what it will drop to on nitrous.
But i agree, let that crap go out the exhaust. My truck wont see over 1300 on the 600rwhp tune at WOT even pulling the trailer. the race tune is another story but im driving the stock turbo really hard then.
James my truck barely hits 1200* EGT's another reason i think mine lasted so long... TONS of air vs available fuel.
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
Cause at first we want 800hp. Then 1000hp. Then 1200hp. Then 1400hp. My theory is overbuild it the first time. I'm not personally sold on wagler parts yet. Everyone I talk to with a solid Duramax have had issues with them. In the big picture its worth paying the extra knowing the parts you installed are the best on the market.
What you mean 'solid duramax'?
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
I have not seen the DX do anything that has impressed me other then revving up in parking lots. How many dx engines are in the 10s or faster list.
That's what I assumed you meant but wasn't sure.
I'm impressed with waglers parts, have used piles of them. The solid head thing is quite a big deal in sled pulling, for one.
But the parts alone will not make power or impress. Takes someone pulling it all together and make it work. Which is why I built & tuned & repaired & spec'd etc etc our competition truck myself. Not saying I'm better than anyone, just that I am in complete control of it. Logistics, time, money, competition, etc make it hard for someone else to do their best. We may in fact do better if we didn't do it this way, but we are not willing to try. It's just a personal drive too. Best way to learn and improve if you ask me.
20dmax08
57
I haven’t seen any videos of a dx doing a 1/4 mile other than the screwed coupe but doesn’t even do the 1/4 just launches. Saw videos of guy sled pulling with the dx 460. Looked like did just fine. *
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
I ran the truck in my sig at 700rwhp daily driven for 6 years. Carrillo/Mahle Race cast. Stock heads. Stock crank. No AF cam! Single tune no DSP. Made around 50 passes with it too. Zero issues besides tearing up a torque converter. I beat the snot out of the thing and it just wanted more. The builder has a lot to do with it too. My cousins truck is setup just like mine was except he runs 100% Exergy, ported heads and a 472 TCT. He has 110,000 miles on his motor and 215k on the truck.
SmokeShow
6,818
Lawrenceburg, KY
There's at least a couple DX460 engines in big time pulling trucks ("farmer dave" on here I think - LMM tilt body truck of the farmer in NY maybe and I think the Cummins Killer II truck) that are competing with the mighty Cummins. That's definitely no small task! :thumb:
But enough of that talk... we're talking about daily driver 800rwhp builds in this thread...
8,052
that and the fact you dont drive it :roflmao: :hug:
when we tore steves engine down, he had been running uS that no one in their right mind would and his pistons looked just fine. he didnt even delip them when we reassembled it but that truck also never leaves the garage now :D
Fingers
Village Idiot
1,735
142
White Oak, PA
If Mahle did any changes, I have not seen it. But I don't know everything. Maybe the alloy is different.....
1,862
You do know you have to add $3-4500 in machine work with bearings right? And depending on how well they balance the crank will help how long it lasts.
Wow, machine shops around here are $1250-$1750 for that work.
Bore/hone mains, bore/hone cylinders with tq plates, bake and blast the block, thread oil galleys, balance assy, deck the block, measure for bearings and supply bearings, etc.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
I know I paid a lot but I wanted the best of the best. Sure I could get it done cheaper but when I wanted my rotating assembly balanced within a gram at 7000rpm I knew where I had to go. Maybe that’s why my crank is still in one piece after 130,000 miles, maybe I’m just lucky.
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
Just because you paid more than anyone else doesnt mean they are the only ones capable of doing top level work.
I just did two callies crank externally balanced engines this fall. The billet main cap one cost me $2430 in machining, cleaning, and heads jet washed and checked. It was bored from stock size to .040" and o ringed as well. The callies cranks take a lot of mallory to balance, this one took 4 1" slugs and 1 3/4" slug. Balanced to within 1%. Balancing cost $580 alone.
I also did a stock main cap engine that did not need bored and did not need align bored, only honed. The different damper and flywheel setup on this one only required 2 3/4" slugs to balance the crank. Balancing alone was $375. The total machining costs were $1565.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I think many people get internal and external balancing mixed up along with blue printing.
It's almost cheaper now to buy a lml block then to have a full block done.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
What about checking the block and crank for cracks? Polishing the crank? Short fill on the block. Within 1% :rofl: this isn’t the 1960’s
