Princeton, N.J.Where is the truck currently?
U didn't answer the question dmax...for every good trans builder out there there are 100 bad ones, sorry just being honest
Well....haNothing wrong with them re using your trans as the core to build on. As long as they replace all the parts that are / were bad. I doubt anyone here really knows what BD puts inside those units, so little insight will probably be shared as to what the problem might be.
What happens when the trans "goes out" each time? Just limps? Overheats?
I've had dmax tuner, starlite I believe that's it. Performance tune, 100 over sound about rite? 2006 lbz. Built motor around 700.h.p. It isn't beat for sure, welding rig rite around 11.500lbs w out camper.What kind of tuning are you running and power level? What year truck?
10-4 20dmax08! U have a contact?I got Evans kit in my Duramax. Installed it myself was quite a chore lol. Evan was a lot of help answering calls and texts. I’d buy another from him in a heartbeat. Awesome guy!
Your about 3 hours from BigDipper and probably the same from Evan. If you would call and talk to them they can probably have a trans waiting that they could swap in and get you rolling again if you can't have alot of down time.I've had dmax tuner, starlite I believe that's it. Performance tune, 100 over sound about rite? 2006 lbz. Built motor around 700.h.p. It isn't beat for sure, welding rig rite around 11.500lbs w out camper.
Camper might get pulled 3x a year if that.
Performance level does best, egts stay down, power is there if I need it
Zerogravity,Your about 3 hours from BigDipper and probably the same from Evan. If you would call and talk to them they can probably have a trans waiting that they could swap in and get you rolling again if you can't have alot of down time.
I sure do appreciate the hell outta u guys!^^ exactly. Just start over, then go after BD if you can.
Evan's phone is 1-413-770-3585. Hes a very helpful person who has an excellent rep.
BigDipper's contact info has been a state secret for as long as Ive been in the Dmax hobby (15 years), so I have no idea what it is.
413-770-3585
Wow man I had no idea!?Keep in mind, the stress on your truck @ 11500# and ~700hp (no idea what you've done to the engine/turbo/fueling) is very similar to guys drag racing @ 7000# running 11s.
I know Evan's trans will handle that, but I cant say anyone's ever done it with a BD trans and had it survive.
Good luck.
I wanted a tough 1Damn man, you built that engine to a T. :thumb: Just call Evan Monday morning.![]()
I wanted a tough 1
I sure will man. Thanks so much for the help!
Ok will do Mike. Thank you sir.You can call me Monday on the shop phone. 714 870 7300. Let Evan do it from start to finish. There may be something else going on and he will spot it.
