LBZ: MPI Small Compound Kit
BigTexas68
BigTexas68
Jan 9, 2012
11
East Texas
I recently bought one of the older MPI small kits that has had the wastegate deleted/ pipe capped off. I will be running this on my LBZ and would like to put a wastegate back on it. Can anyone provide a spec on what gate was on this kit or suggest one that would work?
Thanks,
Thomas
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
I have two of these kits, one has a tial 36 or 38 mm? The other has a similar sized off brand I don’t remember the name I’d have to go look.
Why do you want the gate back in?
BigTexas68
BigTexas68
Jan 9, 2012
11
East Texas
I’ve looked at the Tial 2 bolt flange 38mm and that’s the closest thing I could come up with. Any ideas on the springs I will need?
I tuned the truck this set up was on and I think the boost was a little too high without the wastegate. The smaller tune 600rwhp peaked at 50psi but the tune that made 724 was see boost pressures of 65+ psi.
8,045
That’s not high....
BigTexas68
BigTexas68
Jan 9, 2012
11
East Texas
I will be on stock fuel single cp3 and tune it to around 550-575. The truck I took them off of had dual fuelers ,injectors and built bottom end.
dirtymax36
2nd place is last
Apr 11, 2013
367
i have a brand new 38mm gate for sale. two bolt flange style. Turbosmart brand, ready to rock still in box. bought it for my compound setup but ended up not needing a gate at all
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Save your money. You don't need a gate. It's just another thing to go wrong. Leave the plate tell you go big fuel.
