Just go drive it. It will fix itself.
I have received some stellar advice on this forum in the past, what changed. I will fill my crankcase full of diesel, destroy my engine because I have no compression in one cylinder! Why? I dont have any leaks.Hell I just installed new injectors!
You asked “what’s the worse that could happen”, I answered that question with a very viable worse case.
You either had a piston on the verge of cracking and finally did. Injector stuck wide open and washed the cylinder wall down. Lost an injector cup or seal for the injector from not tightening the injector down well enough or a host of other things.
Don’t jump on us when you want to drive a truck and hope it fixes its self. As it’s been said before, you need to get your ass back into the truck and find out WHY you have no compression
I suppose it's possible you may have a bent or broken intake valve pushrod. If the intake valves aren't opening it can possibly give no compression on a cylinder. Do a leakdown test on number 7. Any way you look at it the valve cover has to come off.
Well I’ll be damned, I wasn’t the only one this happened to :roflmao:
But the question remains, WHY. I set all valves to .012, I have read where many set there's to .010. I checked the lifter thinking maybe the roller got egg shaped somehow, looks perfect. Oh well, guess at 350k it probably was time for head work and gaskets anyway. Just hope it doesnt happen again.
