1971 Chevelle Duramax Swap and Build
calereeves
Displaced Texan
Jul 13, 2011
135
I've been dreaming of swapping my 78 trans am for years (keep it a T/A 6.6)... can't wait to see more pics!
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Got the belt routing all figured out and mounted, hidden out of the way. PS pump is a Sweet Mfg. pump flowed to factory spec, using their BBC mount/tensioner.., with a little machining on the back side to fit the Dmax block/head layout. Belt is a short 53 5/8”
Deny
Oct 30, 2016
23
This will be a sweet ride !!!! what do you plan on useing for rad and air to air???
JoeyD
WTF
Apr 21, 2008
51
I want to do this to my 71, I have an 06 Dmax van I want to use as a donor.
I can’t wait to see more pics
Aug 22, 2009
121
Update! I have been slacking on my updates, but as some of you may know that car was at Sacramento for the NHRDA event. It is not race ready yet, but will be soon. It is currently getting the cage installed, which will take a few weeks, then it will go back to Russ for some final touches and then hopefully up to Idaho Rob for some dyno time and EFI Live magic. After that, time to shake it down on the track!
Here are a few pics.
Aug 22, 2009
121
The cage is going in now, and it is looking awesome. Bonus...we found an original build sheet under the rear seat! Doesn't look too bad for being 47 years old!
Tothemax
xgmtech
Oct 16, 2014
607
new york
have any pictures of the oil pan in the car? wondering how all that fit to the cross member and how the ground clearance turned out
