Negative. There still isn’t anything that will work reliably for a street vehicle and bolt in a stock truck. A drag truck, yes.
A 1100-1300 off the shelf coil spring will not work without coil bind. Coils are flat out too thick due to coil size constraints on a qa1/Viking shock to work correctly.
I’ve been down this road and back in design for coilover setups as a bolt in deal on stock trucks. The spring is my only hold up and I’ve gone round and round to get something for my needs with no help. Even willing to pay tooling and buy quite a few springs.
If you ditch the stock frame mount, you open up a whole new world for options. I have a thread that explains finding spring rate and many other pieces of the puzzle here. It’s not hard to search and find it.
The stock lca mount will hold the truck just fine. The stock frame mount will as well but if you bottom out a time or two, it will start to distort and need reinforcement
James is your man when it comes to coilovers. He helped me with figuring out what I needed. I may not have followed his suggestion fully but the man knows his shit! And yes my setup was in my drag truck but it was 2wd. I never messed with compression and rebound for the street as I had the strip setup pretty good and didn't want to mess with it.
