LLY truck to LBZ engine swap question
1,675
I can't find a definite answer on the gas pedal some threads say yes others say no.
If I do need it, I need to see If I can get it from the donor truck before it disappears...
I have the BT DieselWorks 2004.5-2005 LLY to LBZ conversion harness on order to simplify that part of it and reduce the risk of making a mistake.
3,589
Moved to Repower/Transplant.
Replied to your PM about the swap. There also should be extensive info in this section somewhere about it. Or you could PM Russ (RPMmotorsports) about it.
1,675
Thanks. I saw this thread which is where some of the confusion comes from.
The BT DieselWorks site does mention need for the LBZ pedal either with there swap harness.
https://www.btdieselworks.com/colle...cts/2004-5-2005-lly-to-lbz-conversion-harness
rfletes79
656
196
Galt, Ca 95632
You will need the lbz pedal along with the pedal harness. 2 different pieces.
Your lly pedal with the lly pedal harness will plug in, but not work.
1,675
Thank you!
I know it was needed on the LB7 equpied vehicles Just wasn't sure on the LLY equipped.
He should still have it so I will try and meet up with him and grab it.
Hoping to get a few more pieces from him that I will need.
1,675
Here are the PN if you end up needing to purchase them,
15233970 pedal
15233968 harness
Thank you,
Hopefully I can get them from donor chassis but if not I will order them from the dealer.
He makes most of his money on the engine trans combo's everything else's he qouted me was cheap.
1,675
15233970 pedal
15233968 harness
There telling me the bracket it mounts to is different as well.
I believe I will need 15268739 Bracket.
rfletes79
656
196
Galt, Ca 95632
That one I’m not 100% certain. You may be able to modify your old bracket but if you can’t that LBZ shouldn’t be too expensive.
I got a converted LB7-lbz truck at my shop right now, I’ll look at it in the am and see what it’s got.
Cougar281
1,980
406
St Louis, MO
You will need the LBZ bracket for the pedal. The LLY doesn't have a bracket per se, whereas the LBZ pedal mounts to a stamped steel bracket that bolts up to the same bolt points as the original pedal.
Sent from my 2PS64 using Tapatalk
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
:thumb: ^^^ don’t forget the bracket between the petal and floor.., you need it! Make sure you get the black plastic CAC piece on the EGR horn with the acordian boot..., makes life easier adapting to the LLY IC:hug:
1,675
Any chance you have or can find a picture of this for me so I can see what your talking about???
That way I can see if I have it or need to source it.
Thanks every one for your help! :thumb:
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
You only need the EGR side and the acordian boot. Use the stock LLY/LB7 boot on the IC, then cut a 3.5”L piece of 3” SS tube and bead roll the ends. Use this piece between the IC boot and acordian boot.
1,675
Thanks for the tip!!!
Where are you lcoated in Central Valley Cal???
