Probably a long shot on here but I know that there are a few of you running bagged setups. I haven't found a good source what are you guys running for the front setup in air bag suspensions.... as in slammed trucks, frame laid to the ground. I've always wanted a lowrider for the next truck. As for the rear, I already figured out that part which is pretty easy. The front is a bit different since I do use my 4wd on several occasions on slippery farm fields. I do plan on putting the truck to slightly lowered height (to which the cv angles allow) when driving but lay it to the frame when I park it. I live on rough roads, I'm getting tired of the stiff ride with torsion bars and lowered shackles. Time for something different.
