$130 for the 2 sleeves and $300 for the specific machine work and then an additional $200 to torque plate finish hone all 8
.0048whats piston to wall clearance now? ive always been concerned with pressing old sleeves out, pressing new ones in and not distorting the cyl next to it to teh point even with a hone, PTW clearance becomes too large. if it needs a sleeve, i usually have the block bored over so everything comes out nice.
We're going on 2 seasons on our forgd fingers. We run at either 1250 or 1510, depending on which org we pull with.Are there downsides to fingers pistons besides sound and fuel economy or are those both myths as well? Hasn't Mark Broviak pushed them past 1,500HP or something like that?
Yes. Although both could do either. Cast will hold up very well in most applicationsCast for daily driving correct Forged for dedicated race or pulling truck?
_________________________________________________________if you are going a max of 800hp, there is no need for main studs but if you want to run them, line hone/bore the mains. it would be a good idea to have it done anyhow to open up oil clearance a smidge and make sure you have 0 issues with out-of-round and taper from the bores. if the machine shop knows what they are doing, they will know there is no over sized bearings for the engine and to be very careful not to take too much out.
personally, i would run fingers pistons as well. the extra cost is worth the piece of mind. if you are not willing to switch, make sure you run a turbo setup that will get you to the 800hp mark with a fueling pulse width that is not very high. this will help the pistons live longer. that 4088 wont be enough, you will need a twin on top of it or something else all together.
i would have the block/crank fluxed and checked over but if it was not burning coolant before or gave signs of it, i wouldnt worry about having it pressure checked. they heads should be pressure checked and gone over well though.
make sure you have the 42160 ring set for the pistons, the 41909 do not use the correct metals to be used in a truck looking for longevity out of them.
Run Clevite H bearings, they will be plenty for you. you can get away with stock or P bearings for the cam if the cam is stock or mild. be sure to key the cam and crank shafts.
who will be assembling it?
Sleeved cyl![]()
Fuel system wise, I've made a few high priced mistakes that I think I'm going to have to live with for a couple years at least. The new gt4088r turbo and pedestal being one possible mistake. On the fuel delivery side, I have a 2016 installed CP3 reman-standard size from what I can tell, and then with a no start eBay engine and possibly having a stuck open injector, I went and dropped $2800 on new Bosch factory injectors. I have a new 165gph Airdog4g lift pump, race plug, 1/2" fuel rail inlets and 1/2" fuel pump inlet. Was going to do the 19% over "Bag of Parts" CP3 kit, but then found out that no matter how much air I'm flowing and fuel I'm pumping to the injectors, it won't matter unless I go with either larger injector nozzles, say 100% over ($2K+) or add a supplemental fuel of some sort, i.e. NO2 ($1K) or Propane ($2K). I've looked and Nitros seemed like the least costly, most healthy for the engine option although I would prefer just going with more diesel.I really can't see that charger getting you to the 700-800 mark on fuel only, and definitely would not make for a good atmosphereic charger over stock. What is your fuel system going to consist of?
James,
I was planning on assembling it. It's a first time/pride thing, and I would also wan't to know that it was done as right as could be done by myself without shortcuts. What's your take?
The place handling the engine block is Gregory's Fleet supply and Machine shop. The guy running the show there was recommended to me by a place called Blackwater Engines, a large scale industrial Duramax engine builder here in VA Beach who has long standing ties machine shop wise with this guy. His prices seem high but he seemed genuine, provided I get my block back and not an old block he swapped for a friend. I'm retired military and have trust issues.
I ordered Clevite H main and rod bearings through him for a few dollars less than what I could get online and gave him both sets of main bolts (ARP and factory) with caps but told him if it was more than a quick hone or reshaping the bearings, I would just go with the factory bolts rather than give him an extra $500 to bore the crank bores. Thanks for the good news on the not needing the ARP studs at this point.
He's boring to .020 over for $200, (fluxing I believe), cleaning for $100, and going to pressure test for $150. I asked about him doing an internal balance and he said $500 or $300 if I figured out the weights, which I had done. I've not agreed to that and don't really think I'm going to go that route with him. The Carillos came with a balanced weights card. The PPE Mahle's were all the same less one piston that was 1.5 grams light. From what I've found, that's about the weight of a 1/2 sheet of paper and not worth worrying about as less than 2g total weight per assembly as a whole is minimal for a diesel. Rings and pins were the same. I weighted my old LBZ piston/crank assemblies and they were all over the place, as far as 14grams difference, and all of my bearings looked really nice for the mileage. The new stuff is quite a bit lighter even with the Carillos and heavy pins by about 65g if I remember correctly.
The Mahle rings that came with the pistons are 42160-020 so we're good so long as they don't screw up the block.
The crank is getting keyed at another less confident very general fabrication shop (the first I found) and we're at 23 days now with a promised NLT Thursday of last week.
The cam is due back tomorrow with a mild grind from Shannon's now in Tacoma. I will need to get it keyed locally as well by someone skilled in the importance of precision keying.
I wasn't going to worry about the heads as the engine had great compression 380-400psi per cylinder before I disassembled it.
Thank you for the fueling pulse width information. I had no idea. The Male PPE performance piston set is .020 over and 16.5:1 for $1340 delivered to my door. I would have very much liked the higher compression ratios and genius design from Fingers 17.5:1 but was advised against going higher than 16.5:1 due to more lower end strain risk and higher head pressures. Not to mention from what I found online, I would have paid $2300-$2700 for Fingers and I'm not planning weekend trips to the drag strip.
The GT4088r bearing turbo that I purchased is probably the largest I can likely fit on the pedestal in the valley (hopefully). It claims about 700hp and that's with the standard impeller. The GTX claims 800 plus with an 11 blade so that was my thinking. The turbo falls right smack in the middle of the windshield frame on the Hummer and so it's gonna be close. I suppose I could use the 4088 as a twin and put the factory VV-3788 back in the valley? Not sure how that would work, or vice-versa?
The goal right now is to get my block, crank, and cam back in ready condition and get the thing back together and running so that I can move on to the next stage of the build. Right now I've got a lot out there and no positive forward gains and it's time for me to start reassembling the monster collection of parts if I can remember where they all go! I'll post some pics as well. Thanks for the guidance.
I've got an 07' Allison with the PPE stage 5 kit and Billet Stator triple disc torque converter in the line out of things to put together and have the 263HD manual transfer case that I've put the Merchant's saver plate into.Oh yes, I forgot to ask about the trans , what converter etc , thanks .
It is a heavy pig and I don't expect her to float around effortlessly but the gear reduction 4x4 hubs should provide an amazing launch! Only one place is doing the block up to this point. I agree and definitely need to get a bore gauge to check the shop's work. Just got the cam back a few minutes ago and it looks nice from what I can tell. When you mention piston protrusion, I have not planed the block or heads and they both are clean and factory with the raised rings around the cylinders. I went with the C factory gaskets. and with the 16.5:1 pistons .020 over, I'm not going higher in the cylinder. As far as the protrusion, I was informed the Carillos and PPE Mahle PowerPak pistons would not cause any fitment problems. The machine shop is just boring out the cylinders with the plate on top and testing the block as of now.if you are assembling it and having things done at all different places, i would REALLY suggest you get yourself a bore gauge for rods, mains and piston bores so you can double check taper, out of round, clearances, and so on. i would also get a piston protursion gauge so you can see just how much clearance you have there and get the appropriate head gaskets. does the machine shop have an idea of how much protrusion you want or need for the hp you are after? did they suggest a specific piston to head clearance? things to think about for your build.
to get that turbo any where near its "max" will require a ton of fuel with high drive pressures. not ideal for piston longevity. i have also not seen that turbo make that claim of hp on a dmax. it may be a gasser hp claim you are reading. i would put that 4088 in the valley and put a twin on top of that, then run some decent sized sticks like 60-100% overs. OR since this thing is an LBZ, i would do a danville 68 in the valley and a 483 or 485 over top of it. neither will be a cheap setup but it will help get you on a safer power level if you plan to use that 800hp quite often in that heavy pig.
