How in the world did he get a Dmax pickup down to 4260lbs?!?
Pretty sure that's the truck he posted about after rudys meet. With the fiberglass clip and stuff
[FONT=Courier New][U][B]## Screen Name Time MPH Body Year Engine Weight Tires[/B][/U]
1. RPM Motorsports 8.640 166.17 [THREAD=56383]Nova[/THREAD] 1973 LBZ 3460 33.5x16R15 Hoosier
2. bcdeutsch731 8.810 158.33 RC/SB 1969 LLY 4650 Drag Radials
3. IBDMAX'IN (Skeeter) 9.924 145.23 RC/SB 2001 LB7 6250 28x14.5 Hoosier Quick Time Pro on MT 16x12
4. Dan@PPE 9.947 142.04 RC/LB 2005 LLY 6200
5. prostreeter600 9.978 136.39 RC/SB 2006 LBZ 6000 325/45R18 Hoosier Drag Radials on Raceline 18x9
6. THduramax 10.111 136.36 RC/LB 2006 LBZ
7. Harbin_22 10.419 130.28 CC/SB 2010 LMM 6860 30x14 M&H Cheater Slicks
8. sickdiesel (OverBuilt) 10.429 134.00 CC/SB 2007 LBZ 6425 305/45R18 Nitto 555r DR's
9. MarkBroviak(Wht Lightng)10.483 139.04 RC/LB 2006 LBZ 5850 30x14R16 M&H Slicks
10. cafryer 10.514 132.58 RC/LB 2001 LB7
11. TROJAN366 10.522 132.6 CC/SB 2005 LLY 6860 30x14 M&H Cheater Slicks
12. PIG 10.5264 129.20 RC/SB [THREAD=66903]1983[/THREAD] LBZ 4600 315/60R15 MT Drag Radials
13. meshanic (1500) 10.5816 133.97 RC/SB 1999 LLY 5400 315/35R20 Nitto NT05 on Fuel
14. Kat (Casper) 10.59 128.9 EC/SB 2005 LLY 6420
15. hondarider552 10.65 134 RC/LB 2003 LB7 5750
16. CaptPhil 10.672 132.78 EC/SB 2005 LLY Nitto 420s
17. 2themax2 10.687 129.06 CC/SB 2008 LMM 6700 30x14R16 M&H Cheater Slicks
18. smkndmax05 10.698 126.85 RC/LB 2005 LLY 6400 Hoosier QTP
19. Subman (White Out) 10.703 130.39 EC/SB 2006 LBZ 6650
20. Rhall 10.72 128 CC/SB 2002 LB7 6900
21. othrgrl 10.74 126.76 EC/SB 2005 LLY 6700 30x14 M&H Cheater Slicks
22. bigbird 10.76 127 CC/SB 2002 LB7
23. mike diesel 10.867 130.60 CC/SB 2005 LLY 7000 Falken Wild Peak A/T
24. bluessmax 10.87 128 RC/SB 2006 LBZ 5450
25. scottdmaxlly 10.9022 127.44 CC/SB 2005 LLY 6800 30x14R16 M&H Cheater Slicks
26. maxpower91 10.937 127.16 EC/SB 2002 LB7 6900
27. WisconsinHick1 (The Rag)10.955 128.35 RC/LB 2001 LB7 ~5700 30x14R16 M&H Street Slicks
28. Utahski 10.97 125.55 CC/SB 2004 LLY M/T DOT Slicks
29. BHoward6.6 10.984 124.88 CC/LB 2006 LBZ 7000 305/50R20 Nitto 420s
30. dmaxdrid 10.985 128.49 CC/SB 2006 LBZ 6850 305/45R18 Nitto NT05R
31. Vsouth 11.02 125.62 CC/SB 2006 LBZ 7600 305/50R20 Toyo Proxes S/T
32. coker6365 11.0508 125.08 RC/LB 2006 LBZ 6400 305/50R20 Nitto 420s
33. DMAX497 11.065 132.76 CC/SB 2007 LBZ ~7100 305/50R20 Toyo Proxes ST2
34. emiller3 11.08 127.86 CC/SB 2007 LBZ 6800 28/11.5R16 ET Street
35. nmband13 11.0830 125.17 CC/SB 2001 LB7 7400 305/55R20 Nitto 420s
36. joegorby 11.0975 124.04 CC/SB 2010 LMM 7200 305/50R20 Toyo Proxes
37. juddski88 11.12 123.9 EC/SB 2001 [POST=636025]Dr. Pepper[/POST]
38. Dan@PPE (2WD) 11.17 126 CC/SB 2002 LB7 6750
39. SickLL7Crenshaw 11.1805 123.76 CC/SB 2005 LLY 6800 30x14 M&H Cheater Slicks
[COLOR=Blue]40. dmax02 11.199 120.01 EC/SB 2002 LB7 ~6900 Hoosier Drag Radials[/COLOR]
41. DetailsUnlimited 11.2493 121.29 CC/SB 2006 LBZ 7000 285/60R17 Toyo Proxes on H2s
42. JKholder 11.250 125.63 Suburban2001 LLY 7250 305/50R20 Nitto 420s
43. rfletes79 11.272 118.16 [THREAD=50860]Chevelle[/THREAD]2004 LB7 4200 30x13.50 ET Streets
44. delong_1 11.27 105 EC/SB 2001 LB7 6500
45. dirtymax70 11.301 120.56 CC/SB 2002 LB7
46. quinton 11.453 121.88 CC/SB 2005 LLY 6800 305/45R18 Nitto NT05R
47. skintback (Sonny) 11.458 124.87 CC/SB 2005 LLY 7350 265/75R16 Toyo H/T
48. dstrat05llyzf6 11.4898 118.76 RC/LB 2005 LLY 6000 295/50R16 Mickey Thompson Drag Radials on Raceline Renegade 8s
49. BLKLMM 11.52 119 CC/SB 2009 LMM 7200
[COLOR=Green]50. othrgrl / Kyle Moore 11.5511 117.68 RC/LB 2006 LBZ 4260 30x14 M&H Cheater Slicks[/COLOR]
52. FC5452 11.571 117.50 CC/SB 2011 LML 7300 305/50R20 Toyo Proxes ST2
52. Gmclbz 11.5721 116.04 CC/SB 2007 LBZ 6800 295/50R16 MT Radials
[COLOR=Green]53. Tothemax 11.598 116.55 EC/SB 2006 LBZ 6840 305/55R20 Nitto Terra Grappler[/COLOR]
[B]Gone[/B][COLOR=Red]
54. DIESELMAFIAPER.LB7 11.61 119 CC/SB 2003 LB7 7200
55. Low366Dmax 11.632 116.47 CC/SB 2007 LBZ 6800 265/75R16 General Grabber 2
[/COLOR]
[B]The balance of power:[/B]
LB7 13 25% [COLOR=Gray]#############[/COLOR]
LLY 16 30% [COLOR=Gray]################[/COLOR]
LBZ 18 34% [COLOR=Gray]##################[/COLOR]
LMM 4 8% [COLOR=Gray]####[/COLOR]
LML 1 2% [COLOR=Gray]#[/COLOR]
L5P 0 0%
[POST=636025]Dr. Pepper[/POST] 1 2% [COLOR=Gray]#[/COLOR][/FONT]
Matt / Tommy - what does the truck weigh, and what tires were used?tommy hager aka THduramax's new slip. first time out on new setup and has a boost leak. 9s coming soon/ 06 lbz rc/lb
A base model 2WD RCLB is under 6000 to begin with. But we did a fiberglass front clip, front bumper, doors, bedsides, and tailgate skin. The framework to hold it all is 1x1 thin wall aluminum square tubing. It has a 5 gallon fuel cell at the rear of the truck. Battery is at the rear. Full HVAC delete. Light wheels and tires, only had two leaf springs per side, coil overs up front. Still does have a full interior except door panels - 2 stock seats, vinyl floor with insulation, headliner, and all. We have not cut any holes in the cab shell or frame, still has a glass rear window and windshield.
We are switching over to a Strange 9" rear, just swapped the 38 lb optima for a 12 lb lithium ion battery with almost double the amprerage, deleted the intercooler. May buy a set of dimple dies and put some holes in cab shell for better ventilation. I'm sure with those changes and gutting the interior and installing one race seat we would be under 4K.
Curious about that lithium battery. What are the specs on it?
[COLOR=Blue] 9. nmband13 10.4560 133.81 RC/LB 2002 LBY7 6200 390/40R17 M&H[/COLOR]
10. MarkBroviak(Wht Lightng)10.483 139.04 RC/LB 2006 LBZ 5850 30x14R16 M&H Slicks
11. cafryer 10.514 132.58 RC/LB 2001 LB7
12. TROJAN366 10.522 132.6 CC/SB 2005 LLY 6860 30x14 M&H Cheater Slicks
13. PIG 10.5264 129.20 RC/SB [THREAD=66903]1983[/THREAD] LBZ 4600 315/60R15 MT Drag Radials
14. meshanic (1500) 10.5816 133.97 RC/SB 1999 LLY 5400 315/35R20 Nitto NT05 on Fuel
15. Kat (Casper) 10.59 128.9 EC/SB 2005 LLY 6420
16. hondarider552 10.65 134 RC/LB 2003 LB7 5750
17. CaptPhil 10.672 132.78 EC/SB 2005 LLY Nitto 420s
18. 2themax2 10.687 129.06 CC/SB 2008 LMM 6700 30x14R16 M&H Cheater Slicks
19. smkndmax05 10.698 126.85 RC/LB 2005 LLY 6400 Hoosier QTP
20. Subman (White Out) 10.703 130.39 EC/SB 2006 LBZ 6650
21. Rhall 10.72 128 CC/SB 2002 LB7 6900
22. othrgrl 10.74 126.76 EC/SB 2005 LLY 6700 30x14 M&H Cheater Slicks
23. bigbird 10.76 127 CC/SB 2002 LB7
24. mike diesel 10.867 130.60 CC/SB 2005 LLY 7000 Falken Wild Peak A/T
25. bluessmax 10.87 128 RC/SB 2006 LBZ 5450
26. scottdmaxlly 10.9022 127.44 CC/SB 2005 LLY 6800 30x14R16 M&H Cheater Slicks
27. maxpower91 10.937 127.16 EC/SB 2002 LB7 6900
28. WisconsinHick1 (The Rag)10.955 128.35 RC/LB 2001 LB7 ~5700 30x14R16 M&H Street Slicks
29. Utahski 10.97 125.55 CC/SB 2004 LLY M/T DOT Slicks
30. BHoward6.6 10.984 124.88 CC/LB 2006 LBZ 7000 305/50R20 Nitto 420s
31. dmaxdrid 10.985 128.49 CC/SB 2006 LBZ 6850 305/45R18 Nitto NT05R
32. Vsouth 11.02 125.62 CC/SB 2006 LBZ 7600 305/50R20 Toyo Proxes S/T
33. coker6365 11.0508 125.08 RC/LB 2006 LBZ 6400 305/50R20 Nitto 420s
34. DMAX497 11.065 132.76 CC/SB 2007 LBZ ~7100 305/50R20 Toyo Proxes ST2
35. emiller3 11.08 127.86 CC/SB 2007 LBZ 6800 28/11.5R16 ET Street
[COLOR=Green]36. Low366Dmax 11.095 125.04 CC/SB 2007 LBZ 6800 30x14R16 M&H Cheater Slicks[/COLOR]
37. joegorby 11.0975 124.04 CC/SB 2010 LMM 7200 305/50R20 Toyo Proxes
38. juddski88 11.12 123.9 EC/SB 2001 [POST=636025]Dr. Pepper[/POST]
39. Dan@PPE (2WD) 11.17 126 CC/SB 2002 LB7 6750
40. SickLL7Crenshaw 11.1805 123.76 CC/SB 2005 LLY 6800 30x14 M&H Cheater Slicks
41. dmax02 11.199 120.01 EC/SB 2002 LB7 ~6900 Hoosier Drag Radials
42. DetailsUnlimited 11.2493 121.29 CC/SB 2006 LBZ 7000 285/60R17 Toyo Proxes on H2s
43. JKholder 11.250 125.63 Suburban2001 LLY 7250 305/50R20 Nitto 420s
44. rfletes79 11.272 118.16 [THREAD=50860]Chevelle[/THREAD]2004 LB7 4200 30x13.50 ET Streets
45. delong_1 11.27 105 EC/SB 2001 LB7 6500
46. dirtymax70 11.301 120.56 CC/SB 2002 LB7
47. quinton 11.453 121.88 CC/SB 2005 LLY 6800 305/45R18 Nitto NT05R
48. skintback (Sonny) 11.458 124.87 CC/SB 2005 LLY 7350 265/75R16 Toyo H/T
49. dstrat05llyzf6 11.4898 118.76 RC/LB 2005 LLY 6000 295/50R16 Mickey Thompson Drag Radials on Raceline Renegade 8s
50. BLKLMM 11.52 119 CC/SB 2009 LMM 7200
51. othrgrl / Kyle Moore 11.5511 117.68 RC/LB 2006 LBZ 4260 30x14 M&H Cheater Slicks
53. Gmclbz 11.5721 116.04 CC/SB 2007 LBZ 6800 295/50R16 MT Radials
54. Tothemax 11.598 116.55 EC/SB 2006 LBZ 6840 305/55R20 Nitto Terra Grappler
[/COLOR]
LB7 12 23% [COLOR=Gray]############[/COLOR]
L5P 0 0%
Other/Combo 2 4% [COLOR=Gray]##[/COLOR][/FONT]
Do you want this counted as a LB7, LLY, or Other/Combo (where I have it now)? And are these M&H Cheater Slicks?Same guts, lighter chassis, with my 02 LLY hybrid RCLB - M&H 390-40-17 - 6200lbs with driver, 369/484 fuel only
