well I was able to use my adjustable traction bars to pull up 2 degrees on the pinion. that for the better part solved the vibration and noise I would get around 60 and up. I know I cant leave it like that because is got the leaf springs over (pre loaded). now the front leaf spring bushing squeak. I have new pro comp 2.5 degree aluminum shims siting in my shop. I need advise on the best way too use them. I know what way they need to face but I'm not sure if I put them right on the diff pads or between the lea and overload. if they go on the diff pads the centering pin wont be long enough to go into the diff. plus I was would like to remove the over load springs. can I pull the overloads out and put the shim under the spring pack with lets say a 6'' long 2.5 wide .250 thick mild steel plate under it with 5/16 hole in the center so that I can tighten everything together with a new center pin?
sorry for the book and thanks for input
