$4000 machine shop bill!!
TheDirty06
Sep 28, 2014
115
Horton, KS
My builder today sent me the invoice for the machine shop bill so I can keep track and it was $4000!!! I was expecting $2500-3000 holy crap!
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
Mine was $4500 for bearings, short fill, .040 bore, line bore, key the crank, balance and assembly. He said it would be more next time because he didn't know diesels were so dirty. It was the first one he did.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Mine Was 1500.00 ish. Bore .20 Over, Line bore, Hot tank, Install Cam Bearings, External Balance, Machine heads, Machine Deck, Key Crank, New valve seals installed...
3,781
355
Considering that includes assembly, tolerance checks, and all the normal machine work, it isn't unreasonable.
Well, it is, but it is perfectly normal for a diesel.
henery97
206
Nebraska
Ya, but you assembled yours yourself. OP had his assembled by the machine shop it looks like. That is a fair price for disassembly, machine work, & reassembly. I wouldn't complain about that at all.
TheDirty06
Sep 28, 2014
115
Horton, KS
Yea I'm not upset or anything. Just wasn't expecting that. I searched on here forever to get an idea and 2500ish was the average. Kind of a weird deal the machine shop did the assembly so I'm assuming the shop my truck is at is just gonna put it in.
torqued2dmax
646
Brookville, PA
I guess you didnt know you dropped your eng off at a machine shop /eng builder ? If all the clearances are good you made out just fine ! Good luck with the build !
TheDirty06
Sep 28, 2014
115
Horton, KS
I dropped it off at a shop thinkin they did the assembly and install. I didn't know they had the machine shop do the whole thing minus the install
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
You will learn that many of these "diesel performance shops" dont build there own engines. More of a bolt on shop. Takes true talent to build them.
For them assembling it that is a fair price. It takes a lot of time and liability.
8,054
4K isn't too far off for all that but I have some questions.
Why does it not show any head work? Put new heads on?
Was the cam key'ed as well? It's not on the invoice
Why are they not giving you the actual full list of things done on the engine from the machine shop?
Doesn't show anything about freeze plugs, what bearings used, bottom end o rings used/cost, etc.
Not trying to alarm you but they are missing some stuff that is benefitial to you for down the road in a sale or in a rebuild. I usually have a 4-5 pages of stuff for a customer showing clearances, specs, costs, and what exactly is in that engine
3,422
Nope, that wasnt unreasonable considering what was all done. Diesel = Gourmet, even at the machine shop.
TheDirty06
Sep 28, 2014
115
Horton, KS
The shop isn't done with the heads yet. They're getttin completely redone they needed everything.
The cam is a wagler af cam so it was already keyed. As far as the rest I'll ask for a full list when I pay the final bill. So like you said it'll help down the road.
