IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Not just what I did today but getting through this project day by day of 01-02 front end swapping my lbz and swapped out the s468 for this Forced Induction s476 and getting the body prepped for a color change and two tone on the truck and last but not least redoing a bunch of interior since the truck got broke into a few weeks ago.
So all of the 01-02 sheet metal matches up to the LBZ cooling stack? Or did it require a lot of modification?
3,589
I don't see why it wouldnt. GM would've fit the stack to the truck, not the other way around. Looks good, Dom. Love the 01-02 look.
8,236
it drops right in. i had highly considered the LBZ cooling stack swap in my truck for the cooling capacity. the difference is the metal top bracket rises up higher than the older models but the rest of the stuff goes right in place.
Sep 13, 2016
SLC, UT
you are my hero! swapping those ugly cat eyes for the best front end :D :woott:
Thanks man! Can't wait to see how she looks after all said and done! Welding all the rivets closed and smoothing the royalty core grille today for a cleaner look hopefully lots to do I'll keep updated on here
Sep 13, 2016
SLC, UT
Only thing I've had to change to make fit is using an lb7 trans cooler, and making some bumper brackets. Everything else is direct bolt on!
wilrob
Back in the Motherland
Sep 14, 2016
366
Dallas, TX
Finally installed my rail pressure gauge. Made me hate the EGR even more. Smaller hands would have helped. Works like a charm though!
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Finish my lift tear down! Pulled my heads, tails, fogs and third brake as well for some clear coating. Tore my flares off and selling them and since I'm no longer running 14's i ordered some DuPont paint of my trucks code!
Lparrill
And here we go again
Jul 30, 2010
452
12
Lander, WY
Adding more weight to hold the garage floor down when did you last drive that mofo
Lol I've been driving it in Colorado. Even been putting it to work pulling a trailer and centrifuge every now and again. Now that the intercooler is installed I can finish the nitrous install.
Now that's a tight project I remember doing mine.
Actually wasn't nearly as bad as I anticipated.
