LLY: F#%$&*$@ new guy!
Switch
Jun 21, 2017
Evansville, IN
Sorry guy been stalking awhile haven't joined. So I did today and ill upload an avatar and pics soon.
Picked up a new too me but fairly well used LLY. Still trying to piece together what was done to it.
What I know:
EFI Live with DSP5 switch (no clue what tunes are) it will be seeing the duramax tuner soon to get it retuned.
AFE Intake
5" Straight Exhaust
6" Lift
37" Tires (modded fenders to fit)
Steel driveshaft
Has a banks 6 gun (not hooked up thankfully) sitting in it.
Issues so far
Headlights distorted - replaced with projection
Grill painted black - Replaced
CV boots ripped - Have Two new axles that are going in tonight
God Awful brake rattle - Have new hardware that will go in tonight
Surging issue around 1400 rpms - I assume im looking at an FPR soon
Vibration around 50mph - I think I have narrowed this down to an unbalanced rear driveshaft (tires are getting balanced tonight)
So far I have done oil, Fuel filter, Tranny fluid, Transfer case service, rear diff service, replaced headlights and grill and drove
Thanks for all of the knowledge (that I stole) and look forward to learning more!
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Injector #2/7 harness rub and connections. Also ignition switch.... i learn something new once a month. Welcome
Switch
Jun 21, 2017
Evansville, IN
Welcome!
Danville Performance is going to be a lot closer than Duramaxtuner :thumb:
Just wanted to update you this is where i ended up going.... great people there. More than happy. Ther tune made great dyno numbers...
Sent from my SAMSUNG-SM-G891A using Tapatalk
8,045
Welcome! pics of current CV angles please. adding new axles may not stop you from tearing those if the angles are severe.
Switch
Jun 21, 2017
Evansville, IN
Sorry i missed this, ill get some pics... but the boots were old and neglected.. the new axles are holding up nicely.
Switch
Jun 21, 2017
Evansville, IN
Did you end up finding the vibration cause?
So i balanced the tires, had the transfer case, and transmission flushed and the vibration was gone. However its starting to come back again...i think its a tire balance problem again.... one tire was pretty far off last time.
Switch
Jun 21, 2017
Evansville, IN
Here is a pic of the angle its really not that bad
8,045
10-4, Yeah thats not bad at all. did you keep the old axles? if they didnt run completely dry, you can buy a boot kit and fix them up. they are stronger than the replacment stuff out there, plus the boots dont last as long on the aftermarket stuff. even the replacement boots dont last as long as stock.
Switch
Jun 21, 2017
Evansville, IN
No the passenger side was run dry so long it almost fell apart when i unbolted it... i scrapped em..
