Biggest streetable Injectors
The Kansan
Aug 30, 2013
179
Topeka, KS
Im in the process of building a motor and i was curious what some of you built motor guys are running for injectors. Id like to be able to drive it as smoke free as possible and occasionally tow a trailer. Where do you think 65% over injectors would get somebody horsepower wise?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have 100s and they are clean as a whistle on my small tunes. I would think LB7 65% overs would put you over 900hp if you pushed them.
8,235
Would 2 stock pumps hold rail pressure with 100 overs?
depends on the pulse width you want to run
45% over injectors have made 1000rwhp track proven with enough turbo. no reason 60/65% overs cant if you have the right turbos.
i run 100% overs on my dd/tow rig. they are not as clean as stock injectors but they are no worse than the LB7 45% overs i use to run (have a LLY top end now). its going to take tuning time to get them dialed in just right but many tuners have dealt with 100% overs in many different configs now that they should have good bases to go with.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have an LBZ pump and an LLY pump with 100s and it doesn't have any low rail issues. I am pushing them with big pulse width too. 1125hp at the wheels on a 90* day.
zakkb787
<that’s not me...
Sep 29, 2014
2,344
54
Granite Falls NC
Just looking at what injectors I'll need to make 4 digits with an s475 and what kinda pumps. Was thinking 100s and another SuperSport pump. Didn't mean to derail the thread:hug:
gmduramax
Shits broke
Jun 12, 2008
4,190
328
Nor cal
I'd go at least 150's. two healthy stock pumps will do 1000
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
I have 200s on a single 12mm, no problems holding 29k rail pressure. A little smokey on the street till you learn how to drive with big injectors.
Wikid
Machinist and Know things
Oct 21, 2016
88
Texas
I am running 100s. Runs good but they haze and tend to smoke a good bit more than when i had 60s. It does take a different style of driving to not completely smoke out the road.
TheDirty06
Sep 28, 2014
115
Horton, KS
I'm gonna be running 100 overs and dual LBZ pumps whenever my motor is done. Hopefully it'll be done in a couple weeks.Ill come run around Topeka when it's done lol
