Turbo Inlet's
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
So I just tried to fit the Kodiak turbo inlet on with the ProFab Y Bridge and it wont clear by about 3/8" I was thinking I could cut it down and bond a piece to cover it or go with some aftermarket unit.
Thoughts?
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
Why couldnt you just pull the y bridge and change the angle of the inlet and reweld it? You dont need much to make everything fit. It looks like you have room from the picture. Is another accessory blocking you from doing that?
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
I must be having this issue because of the Kodiak inlet, It might just be easier to put a truck one on, or an aftermarket one. Seems like plenty of guys have Y Bridges and this works fine. If it was an inch longer id be set. I honestly don't want to pull the bridge because if I do a HSP or SDP might go back in its place $$$.
3,419
Thoughts?
I would call Rick in the morning and ask him his opinion. He may have seen this problem before, and may recommend a solution. Could be you found something he didnt anticipate, too.
ChrisPerry
Apr 4, 2016
209
Ventura, CA
I'm not familiar with the lbz mouth piece, can you loosen it and rotate it up for added clearance? If so you'd just need a little linger intake hose.
