Pulling bed by yourself
WVRigrat05
3,149
French Creek, West Virginia
So, trucks been parked, it's up for sale (which it probably never will), and I want it spotless again, when I pulled the bed on my LLY, I did it at the rig with a forklift but that's not an option nowadays.
So how have you guys been pulling the bed on your own? I was thinking some long straps and a snatch block but not sure how that will work.
FC5452
301
Eastern PA
Two people can pick it up, can't ya get a buddy, a set of horses, and two 2x4x10 and set it down?
Otherwise you could try straps and grab it that way
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
By myself I would use 4 straps or chains to the inside hooks of the bed corners, use a comealong from the rafters or a tree and lift it up and pull the truck out.
six5creed
1,046
58
N.C.
I pulled mine like Albert said. I strapped it corner to corner cross ways and lifted it straight up by myself with a hoist.
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
If you have a steady branch throw a strap over it and tie some lifting tackle (pulleys ect...).run a sturdy 2x6 or double stack 2x4 for more back bone under the bed rails. Slowly lift bed to find center and viola! How i did mine by myself. Use as wide of a piece of wood under the bed rails so you dont bend them.. hope that helps
TLyons90
Apr 22, 2013
1,631
Greenville, SC
I considered pulling the bed on my last truck. My thoughts were back under a tree or 2 with some good size limbs. Hook 4 tie down straps to each hook inside the bed. Then 1 bigger strap in the middle that hooked to the trees. Then ratchet up on each until I could drive out from under. Not sure it would work... But my help!
3,590
It sometimes pays to have a teenage son with friends. ;)
But I like the way Burn and Slim did it.
02greysixer
1,829
North Central FL
Full redneck here. Big branch, snatch block and a winch. Strapped the bed like everyone said
Sent from my SM-G930P using Tapatalk
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
Love this! Y'all would shit a brick if you've seen some of the ways I've done things.
I have lifted my whole truck with 10ton overhead crane, and worked under it. I did park two 6000lb forklifts under each end to act as a life saver:thumb:
As far as lifting the bed, I've always used a 4x4 cut to length under the bed rails, find center of gravity and lift. If worried you can always C clamp the 4x4 to the bed rails using 2x4 block on top to keep from reforming the bed rails.
