LBZ: Break in oils
colfmas97
May 16, 2017
31
Wyoming
What kind of break in process did you do? I got wagler rods mahle pistons in mine idk if it really matters
White Lbz cc/lb, 111k, efi live dsp 5 by Craig at infinity diesel, 5 inch straight, mbrp DP, SDP y bridge, egr delete, S&B intake, 66mm Danville drop-in, Airdog 165, PPE stage 4 trans, stock engine, stock injectors, stock cp3, Ppe rail fittings, 610 rwhp 1197 lbs, leveled, fuel maverick 20x10 -24, federal couragias 33x12.5. Cognito supports and tie rod sleeves.
Lbz died 3/31/17
over fueling stock pistons
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Lbz died 3/31/17
Just drive it. Don't beat it too hard and try and fluctuate throttle position. I changed my oil at 500 and 1000 miles.
Awenta
4,090
Whatever oil you're going to use later and after 500 miles change the oil and giver her hell. Break it in how you're going to drive it. Then change again at 1000 more. Get it nice and hot to seat the rings
colfmas97
May 16, 2017
31
Wyoming
Right on. When you guys filled your engine first how did you guys push oil to the crankcase and through all ports? Just put a socket on an impact and spin the pump by the shaft till I get oil in the crankcase?
Lbz died 3/31/17
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Hit the starter with the FICM unplugged on my LB7
I changed the oil 5 times in 500 miles then every 1000 miles after.
3,587
Id use an oil with a higher % of zinc in it for initial break-in.
Can you figure out why your sig shows within your posts? Its something you have set in Tapatalk on your phone...
colfmas97
May 16, 2017
31
Wyoming
Shoot I didn't even think about that @hondarider552
Lbz died 3/31/17
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
I used delo 400, 600 miles on the motor went to the track and busted off a 11.1@123 that should have seated the rings :woott:
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Lbz died 3/31/17
You don't have a FICM... You need something like thishttps://www.summitracing.com/parts/mel-mpl-101?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-melling&gclid=CPuytfDf-dMCFRB0fgodfVEBvQ
Or build one out of heavy PVC pipe.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Mobil then Rotella after 500 miles, didn't prime it, had it on a 2,000 mile road trip after the first oil change, motor hasn't been under 700rwhp in 5 years now has 55k
8,235
Delo 400 reg dino oil in each engine on first start up. i crank till a mechanical gauge at the last main port shows pressure, the start it.
engine is then ran and checked for leaks till it reaches operating temp. If a new cam is put in, its broke in via the instructions that came with. after that, let it cool and then take it for a drive. let everything warm up and give it a couple WOT runs on a decent sized good tune. it doesnt bother me one bit cause i know the exact specs inside that motor and i want those damn rings to seat! :D
go 500 miles, change oil and cut open oil filter looking for sparkly things. if all is good, new oil and off ya go!
