Piecing together an s400 kit
zakkb787
<that’s not me...
Sep 29, 2014
2,344
54
Granite Falls NC
Hey guys. Just wondering what the bare bones necessities are for putting a s472 in my truck. I know I'll need a pedestal and down pipe. Can I reuse my factory IC pipes for now? What about the oil/coolant lines? And intake. Any way to get the s&b to fit right? Or do I have to order an intake. Just asking because personally to me 2 grand for a few pipes and a pedestal seems a bit $$$ but just my opinion.
deezelpwr
Floating in the Gulf
May 18, 2014
15
BAMA
I am going to do the same shortly when I finally decide on a turbo, I am going to use the fleece install kit, ppe pedestal and a 2" pedestal spacer, profab y bridge and build my own down pipe.
zakkb787
<that’s not me...
Sep 29, 2014
2,344
54
Granite Falls NC
I was looking at the wherli kits. If I get a full kit that's probably the route I'm going but I'd really like to be able to get a 72 on there for less than 3500-4K. Might not be possible but hey worth a shot. Do you have to change the y bridge for an s400?
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
The lb7 style bridge works well with a single s400. I built a kit super cheap but I made a pedastal and intake and downpipe and modified the top of the hot side factory ic pipe, lb7 has a 3 inch boost tubes they just neck down. I just cut the top off and welded a 3 inch prebent and bead rolled aluminum 90 back to the top of it.you will also need an oil feed and drain line which will be roughly 200 I think.
zakkb787
<that’s not me...
Sep 29, 2014
2,344
54
Granite Falls NC
Awesome this is exactly what I was looking for. So ultimately the parts I'll need are a modified hot side pipe for a 3" inlet, pedestal, intake, oil feed and drain line, And down pipe. Correct?
henery97
206
Nebraska
Does anyone sell a reasonably priced lb7 style y bridge with LBZ flanges?
zf>allison
Apr 30, 2013
3,394
elsberry mo
Yes if your running a vband compressor cover you will need a clamp and a vband for the hot side pipe. Also I did a 4 inch down pipe and massaged it in. That required cutting the reducer off of the inlet of my 4 inch exhaust and I did a vband connection there as well. You will need a maf sensor bung for the intake as well and make sure you put it in the right way.
zakkb787
<that’s not me...
Sep 29, 2014
2,344
54
Granite Falls NC
Can you explain what exactly making your own down pipe involves? I keep hearing people doing this but haven't been able to wrap my head around it.
zf>allison
Apr 30, 2013
3,394
elsberry mo
Order a vband for the borg exhaust housing, I ordered a 4 inch 90° bend welded the vband to it and basically added a straight 4 inch pipe that but I didn't have a dipstick to clear because mines a manual trans. Then tie it into the exhaust with another vband. I have a thread about my build somewhere.
ikeG
Oughta Know Better
Apr 19, 2011
2,553
189
Western PA
www.facebook.com
Wehrli kits use 3.5 downpipe and they fit nice. The ats 4" downpipes were flattened and tweaked here & there to clear everything. Installation with the engine in the truck can be difficult. If you ever have the engine out, it's worth it to give the firewall a few love taps with a rubber mallet or dead blow plastic hammer
Briggs0130
103
:hitit:
zf>allison
Apr 30, 2013
3,394
elsberry mo
Thanks guys. So be honest. Is the kit worth buying?
I've never bought a kit but I'm cheap, after building my kit, it's just crazy to think what they are asking for this stuff. Would be way faster and easier obviously with a kit. My truck was down for head gaskets anyway so it was just a bit longer to do that to. Just depends how much time you have to mess with it.
