To AF or not?
wilsondiesel
190
Sedalia, MO
So I have the motor out, head studding it along with porting heads, valve springs, and push rods. Running an ihi with s366 center section in it for Air. I plan to pull the motor again next year and do rods and more fuel. Currently still going to run stock fuel this year. Would I see any benefits with going ahead with a stage 1 or close to stock grind cam that's an AF or should I wait to do an aggressive cam when I do rods and have reliefs in pistons?
Aug 22, 2009
121
Not that this will mean much, but I am not sold on the AF cam. Failures have still occurred with AF cams. If it was me, I would look at upgrading the crank as stated above.
This is just my opinion.
Paul
JDPlowboy
624
The af cam is cool and theory looks good on paper. But I have seen power drops with them. A standard fire will make more power.
Chad006
Drag racer wannabe
Feb 12, 2015
311
Goodlow, B.C.
Do you have dyno sheets/timeslips of cams with same specs standard firing and alternate firing to back this up? I think there is allot more that goes into making power in these trucks than firing order alone. I'm. It saying that it's the answer at all but there has been vibration analysis testing done that shows better harmonics with the af versus the standard firing order.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If the alternate firing order was better, why hasn't GM changed to it?
Why would they continue to risk broken cranks if the fix was that simple?
Why did they completely redesign the crank and lower end of the L5P if the fix was a simple firing order swap?
That would have been SO much simpler, and SO much cheaper for GM to do........ Hmmm....:confused::confused:
Chad006
Drag racer wannabe
Feb 12, 2015
311
Goodlow, B.C.
If you read my previous post you will see where I wrote that I don't believe that it's an absolute solution. But the af cams have been proven to improve harmonics, in most cases guys are swapping the stock can out for a more aggressive grind anyways. Why not install something that is ultimately going to allow your engine to run smoother? To the OP if it were me I would wait for the full build then decide what grind af cam to better suite your build, goals can change between now and then.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Who says it will last longer before breaking? You really think GM hasn't tested this??
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Do you believe they have any benefit?
I believe they might make the engine run smoother at idle and part throttle. Based on what a lot of people have reported. But there's so many variables involved in comparing before and after an engine build that I'm skeptical of even that.
But honestly I'm not the least bit convinced they help make the crank last any longer. I could be totally wrong, and I don't have a dog in this fight at all. But I've not seen any evidence that they actually help make the cranks live so me personally I wouldn't spend one dime to switch the firing order.
Harbin_22
3,858
Southern Indiana
My original engine was built and balanced by the same machine shop as this engine with the AF cam. It is 10x smoother at idle than the first built engine or the two factory bottom ends I've had in the truck. My original built engine made it 5k miles with a brand new LB7 crank and stock cam. Was around 1000hp and I honestly wasn't that hard in the engine. Now this engine received an 80k mile used LBZ crank with a Socal AF cam. It has made it somewhere around 15-17k miles so far and I beat the hell out of it around 1,200hp. It may not be a fix all, but something has made this engine last longer.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Exactly. But there is also the guys out there that have broken brand new cranks with AF cams. And plenty of built motors that have tons of miles on the stock cam and crank and still going. Idk. Just not enough stories like yours Harbin to totally convince me.
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
I would rather have the piece of mind that I gave it a solid fighting chance if I were building a new motor. The AF is not worth it IMO for just a cam swap on a crank that has already seen the original firing order harmonics since the stock cam has already proven to be more than efficient enough to break stock rods/pistons. :roflmao:
I would run an AF with a full build and a fresh crank though as I did on my first build. I used a new LML crank the first go around. The current build is getting a narrow rod Bryant crank from SoCal. There are a few high horsepower people out there than may speak up about their findings as well. The longevity at high horsepower definitely increased with less crank failures for a given time period in the same application. Obviously its not an end all, however, I do think it may help a little. There is really not enough solid evidence to prove one way or another, but its worth a shot to me if I am already swapping the cam for a build anyway. Its a very small cost compared to the total bill, why risk it...
8,235
personally id just go straight to a better crank and move on. you can pick up SF cams cheap now used or buy them new for a few dollars less than a AF depending on where you buy from. I sold my spare lb7 crank knowing that if/when mine goes ill be buying a callies crank and fingers pistons right off the bat. may throw a cam in it but whether its AF or SF will depend on if i really want the smoother idle or if i get a good deal on one or the other.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I whole heartedly agree with this.
Where? I've heard of 2 maybe. Both were around or above 1000hp.
Every other broken crank I've heard of was previously used.
IMO reason GM hasn't changed it is because they haven't identified it as being a problem as majority of the failures happen off warranty or are in not warrantable trucks anyways. Why would they change something that makes them more money down the road?
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
Yep I know what your saying. I went with one not because there's proof they work, but mostly because of all the stories saying how much smoother the engine runs. And with the bill I had, what's an extra 700-800 bucks:rofl:
