Tothemax
xgmtech
Oct 16, 2014
607
new york
Had to leave work for a few hours, to put my wife's best friend down
It sure is tough, and amazing how much they become part of the family. Bo would have been 10 in April.
sorry for your loss. dogs really are our best friends.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
finished removing a dock door that the yard driver pushed out of the tracks with a trailer door. Sure was fun removing that ****er.
3,592
Finished this '65 Impala frame.
Sent from my iPhone 7 via Talkatap
You matched that right down to the weld seam thru the middle. Damn man, nice job! :thumb:
I should ask you some time the proper way to weld brackets to an axle tube.
six5creed
1,046
58
N.C.
Thank you sir. If we lived closer to each other I would weld them on for you!
six5creed
1,046
58
N.C.
Made 2 U-bolts for a customers piece of farm equipment. I don't know how they're supposed to be made but there has to be an easier way. This is the only way I know how to make them though.
5,516
590
Good grief I wanna go do that so bad again. Looks like had a good day.
Yea, it was unbelievable down here this week! No wind and the tuna were biting the jig the best I've ever seen them. We had 17 tuna in 1 hour of jigging and then went to Boca Grande and whacked the flag yellow tails. I love Key West in February, have to head home today, high of 43.. :eek: I'm excited to see my boy and wife though...:)
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
The hilux got a flat, broke the valve stem, and of course when they up armored it they took out the Jack and the bar to lower the spare no one had the type valve stem we needed so I had to crawl under and lower the pare with a screw driver.
six5creed
1,046
58
N.C.
Customer brought a shaft in that he tried to get a 5/32" woodruff key out. Drilled and tapped three 4-40 holes in it and used the only bolts we had then squeezed it in the vise and pulled it out.
six5creed
1,046
58
N.C.
Still working on this fertilizer attachment. Does anyone know where I can buy auger parts? I know they are made in a special roll form machine and this one has a left and a right. It's on a 1" shaft so it shouldn't be that difficult. Has anyone ever made an auger?
caseih03
Dec 12, 2016
13
Moving to the "teardown" team here at dmax (duramax engine plant) I'm off night shift and on to day shift so I'm happy.
Fingers
Village Idiot
1,735
142
White Oak, PA
Easiest to just buy the part, but if you have to make your own...
Use the old one as a guide and tack the end of the stock to the old auger. Now, heat the stock along the outside edge red hot perpendicular to where the stock contacts the shaft and bend the stock around the shaft. You only want to heat that area. Take your time and use clamps every once in a while to keep things straight.
