I'd like to see what you come up with for fuel lines and filters. I need to start piecing my system together.
I went ahead and had exergy take them out to 100 over. They will be working on them monday so that should be quick. Scott is going to get me an lml manifold to go with his up pipes. I have some other little parts i need to get ordered for running my fuel lines direct into the cp3 along with modifying my lift pump to take the 2 micron CAT filter
Sent from my SAMSUNG-SM-G930A using Tapatalk
The turbo coolant lines are hose & the fittings have nipples
That's a thermostat for the turbo that screws into the coolant tube on top of the engine
If you want the braided hose & an fitting look just get some of those braided hose sleeves
Make sure to post up some results once you have it back together, my new setup is going to be %100 identical to yours with the exception of 100 overs and would like to see some feedback.
Can you elaborate on your fuel feed and return setup?
Will -6 from lift pump to cp3 be enough? I think that's what I want to do.
As for return I'm thinking of leaving that all stock for now.
Are you running a stroker or duals in the new motor?
1/2 pushlok hose work great.
For now I think I'm just gonna run the factory feed line. In the name of just getting the truck running as quickly as possible. Then I'll start making it better piece by piece.
