LB7: 11.9 et
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
Well Im looking for an 11.9 ET. Im sure Ill need to build for more and dial down. Recommend me a fuel and air setup! Truck weighs as it sits about 6500lbs. Should be about 6k, or less hopefully, when Im done with it.
melms23
253
WI
S475 over stock lmm on proxies and bmfs got me 12.1.
Had 60k hard miles on the tune, so I figure it had more left in it since the motor never went.
6300lbs also.
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
I went 11.82@114 with 40 overs, cp3k from fleece, box s475/stock, stock motor LLY at 6000DA. CCSB 6750lbs right at 675rwhp or so.
Low366Dmax
Pin it to win it
Aug 23, 2013
185
NH
My lbz went 11.9 @ 6800 pounds with 45s dual pumps and a 366 and went 11.6 @ 117 on nitrous until it decided to snap motor mounts and bend valves
Stancedlb7
Feb 9, 2015
649
SLC, UTAH
Guess I should have mention its an 02 lb7. I leaning towards twins because singles seem to be inconsistent. Im thinking S480 over IHI duals and stock sticks. Dont want to spray either because, I know for sure, its inconsistent.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I have a bd staging limiter that doesn't do the trick on a zf buy would be nice for consistent launches on an auto. There's probably a ton of ways to hit a 11.9, are you gonna be bracket racing?
Stancedlb7
Feb 9, 2015
649
SLC, UTAH
Would like to compete both heads-up SD and bracket SM. So my quickest ET can only be 11.5 but would like to dial 11.9.
Noreaster
2,910
Cape Cod,MA
Twins are nice but also a PITA
I'll say a decent sized single to keep the engine bay fairly open, easier to work on, not relocating the ps battery, not heating up the oil even more & not kill the rods with torque
Some decent sized injectors & hopefully your cp3 is healthy
