current set up
Feb 2016 time to do steering again. Swapped out the inner and out at autozone(reason for not stepping up to a larger tierod deal is availability. Say I wanna go race or sledpull on a Friday and break something, next day I can have the replacement on the truck.)
May2016 had some front end noise. Ended up being pitman/idler arms.
Dec2016 someone hit my truck in the homedepo parking lot. Ruined my bedside. Decided it was time to have her shined back up. Then the trans…..
Jan2017 Having a buddy do all the body work to make her look new again. Didn’t want to do patch kits and bondo and be back again in two yrs. I wash my vehicles everyweek and oil everything atleast every 2 months to keep the rust off. This truck had the usual spots, rockers, cab corners and wheel arches behind the flares. Also adding a roll pan welded in and seemless and a cowl hood.
So replacing both bedsides rather patching 2inches of rust. Plus bedsides save a little in labor compared to having the rust cut out and patch panel put in.
Having both full rockers done. Also could have gotten away with slip ons as only the lower outside was bad and only the drivers side was bad. Passanger was just starting to bubble so screw it. Do it once and be done I hope.
Both cab corners.
Both front fenders
Cowl hood and roll pan in the rear. Only need to figure out how to get an ss front bumper on a 02 gmc. Ive seen pics of them but have not found a site that say it will fit a 2500. So that’s where we are at.
Future places are to have the frame sand blasted and por15 it. Then undercoat it.
Then paint.
Then this summer over to see evan for a trans, lift pump and a max effort tune.
Things I am trying to get done this spring,
-all body work
-some race line wheels-most likely 18s to keep them somewhat light(rims 30lbs ea) and a street tire.
-Energy bushings all over.
-thinking about running djm lca for a 3inch drop and keeping just the 3” shackles in the rear. I don’t want to go crazy with the 3/5 kit but would like to get the front lower and be able to get some more space front the bump stop up front. So I am happy with the height now with just the decranked but the ride isn’t amazing in new England.
I want to run those drop lca and crank the front up to get some more travel.
Anybody ever run these djm lcas in the front and only the drop shackles in the read? I like a little rake but don’t want to go crazy. The rear I would go lower but 1. I like having all the leafs. 2. I would like to be able to run cal tracs so doing the front hanger would kill that.
Any input.. thanks and sorry this is so long. Its just 2 and ½ yrs of the history.
current set up![]()
How many miles do you have on the rare parts tierods?
Yes this is the new winter set up. I am looking forward to having a rust free truck.
and I don't even use 4wd
That has to be the most extensive intro Ive ever read. :rofl:
Welcome to DD.
Noooooooooooooo!!!!!!i am going to have to start a new thread. This ones to long
