08 LMM Battery replacement frequency
Lt. DMAX
Nov 4, 2016
23
Southern Tier of NY
08 Sierra with LMM. Every two years when it gets cold I experience hard starts followed quickly by no starts, unless I change both batts. I have been using Duracell AGMs from Sams.
Is a 2 year replacement frequency the norm?
If not, thoughts on causes?
Thoughts on Duracell AGM vs. Optima?
Optimas are junk anymore.. Not sure on the Duracells.... I run interstate pretty much exclusively and I have great luck.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,538
35
Lexington, Ky
I think I have Autozone gold tops in my daily driver. Deka will be going in when they go out. That's all we use at work they are good
3,781
355
Went through a ton of Optimas when I first got the truck. Got tired of swapping them under warranty, and figured if I was going to have junk batteries, I'd buy junk batteries. Bought the cheapest batteries AutoZone had.
After 6 years, they're done. I'll be putting a new set of the cheapest batteries I can find in shortly. Best value for the dollar I've ever had. Never had a name brand last 6 years.
Sent from my FlashScan V2
Hoffie
Mar 10, 2015
212
Far East LA - aka Phoenix
Optimas sold their name to a lesser quality company and they are not as good as they used to be. Batteries Plus has some good ones that are not too expensive. Did your batteries start smelling like rotten eggs before they died? How often do you drive the truck - less often the battery dies sooner, more often it gets worked harder and seems to work longer. Just my opinion..
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,088
Mexico
We use Dekas here on the ranch. They have been treating us very well so far. I use one 850 CCA on my LLY and it starts in 30* weather with no glow plugs. I'm impressed coming from interstates and continentals in the past.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Yes, Optimas are junk. Went through several of them and I'm done with them. I buy Interstate or from a local discount store called Bi Mart, they have an absolute no quibble return although I've never had to return one to them. Couple of things, you could have a parasitic battery drain that partially discharges batts when parked for periods of time. When it gets started after sitting, the batteries get stressed from the high recharging current. Or your alternator may not be putting out enough to fully recharge your batteries. When I park my truck for long periods I put a Battery Minder (not Battery Tender) on it, the Battery Minder has a circuit that pulses and helps reduce sulfate buildup on the battery plates.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Original GM batteries went 10+ years in the harshest environment you could ask for... Well, one died under warranty and they both sh*t out 2 winters ago. I have Cat batteries in my TBSS and the D-max now. 4-5 years in the TBSS with no issues yet.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I had a set of the original optimas (the good ones) go 12 years. Using a set of acdelco batteries now with a 3 year warranty. We'll see how long they last in this heat.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Between 4 trucks, I've shit out 18 batteries....all started with OE, replaced with Optima, those shit the bed within a year. Running interstates now and those have treated me well. 2 yrs is BS, a decent battery in Vegas will do 4-5 yrs, even with our 110+ summers and 30* winters
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
My LMM came with Interstates when she was born or the first owner put them on there with the 08' stamp on them and I ran them til last winter and finally they fell on their face after 2 years of North Dakota's winter temps. Soooo I swapped them in for the same set just new. Figured 08' to 15' was a good run
Paid $275 after cores
Edited for pricing
elliottw
397
13
ND
My 07 is still plugging away on the original batteries, can't imagine theyll live for to much longer.
5,516
590
My LMM went thru a set every 2 years no matter what brand I used. I drove it everyday usually about 100 miles a day. The LMM just seems to eat batteries...
