-24mm and 305/50R20
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
Looking at getting some new wheels and tires. So far, I'm planning on running 20x10 fuel maverick's with 305/50 20's. Truck is a tad bit lower than stock in the front, and 2 inch drop in the rear. anyone have some pictures of a similar set up with -24mm offset?
malar24
60
NE Ohio
Here's my setup pretty much what you looking for minus tire size. 285/50 r20 20x10 -24 offset 3" drop shackles and the torsion key bolts have like one full crank in them.
carter_44
May 11, 2010
575
AZ
What you're looking for.
20x10 -24
275/55R20
Josh154
1,220
85
Sioux Falls SD
Here's 20x9 +0. Not as wide as you are wanting but gives you an idea of a what a smaller rim looks like. Tires are 295/55
anybody have some of a set of 285/55's? I tow pretty heavy at times. I want to have a load range E tire.
Oh pick me !! Pick me!!
No torsion bolts, 3" shackles, no over load, 285/55/20 toyo at2 "e" 20x12 -44
c5fourj
Occasionally moving quick
Dec 20, 2014
307
Brighton, CO
20x10, i believe they are -12 but i am unsure because i got them off of craigslist.
I had to do the larger fender mod as well as trim the wheel well cover. But once thats done there is no rubbing.
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
thanks for the input guys. I went with the 285/55's. hopefully I don't have to do a ton of cutting. I had 305/55's, but they were mud terrains. Very tired of listening to them howl.
You'll be fine. It'll require cutting.. Look up my large fender mod thread
danzick
playing with fire
Feb 20, 2014
576
Livingston, MT
got them on. They rub the rear of the fenders a fair amount, but not enough to rip the wheel wells up yet. Also just barley Rubs the washer fluid tank. Really glad I didn't go with the 305's. It's a little higher than I would like, but my axles are still flat and I wouldnt dare go any lower until I do the fender mod. Currently working on getting my factory front bumper color matched, and my roll pan painted. Cant wait to get rid of the big ugly bumper in the front and the factory rear.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,758
526
P.N.W
Looks good man
