As long as the new lml tube is the same overall length as your old dipstick you will be fine.
If the driver's side fit like the stock passenger side dip stick you going to have fun. I had to cut about 1 inch off the bottom to get it in the trans. I even dropped the transmission cross member about an inch and it still didn't help much.
Best time to install it is when you drop the transmission.
I only cut off the top. How does a different pan affect it? The valve body and where the tube goes in are still in the same place right?
Are you talking about the level when the oil is circulating in the pan changing because of the different design?A deep pan will alter the geometry of the fluid level. Shallow pan is tapered and deep pan is square. You'll want a lower level on the stick.
I'm not cutting it, if it doesn't fit correctly, I'll use the new seal on the passenger tube and bend it to fit, then have Evan help me out when it's built
Mike, while your on the line. Any recommendations for what else I should do while the trans is out for the build? Seals/bearings/lubrications etc? I don't want to have to pull the trans after the fact for something I could have done then, ya know? I'd ask Evan, but he doesn't email and I hate bothering people via text cuz I know I hate receiving them lol.
Thanks for all the input on this ladies, I just realized it's a long weekend so I've stocked up on Guiness. I think I might even get a vacuum on the floors hahah
