Road Armor bumper, everything running hot.
Sep 24, 2013
13
52
Connecticut
Anyone else install a Road Armor bumper and find that the truck runs much hotter?
Coolant and transmission seems to be running much hotter when towing.
I am thinking about opening up the center section where a winch could go.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
French Creek, West Virginia
Yep. I had a home built bumper, truck was warm, had the trans built and motor and it overheated daily. Cut a 5"x-18" hole and cold as ice.
Same with the fab fours on my lmm. 15-40 degrees hotter. Cut same size hole and it's better than stock.
Sep 24, 2013
13
52
Connecticut
The opening for where a winch could go is 2"x8"
I could easily open it up to 6"x22"
Might be cool to install a couple hinges and install 12 volt actuator to open it up when it gets hot.
Hoffie
Mar 10, 2015
212
Far East LA - aka Phoenix
I installed my winch bumper last month and my temps are running hotter by 20, as well. Installed a winch so I need to find another way to get more air.
Robby05
Jul 25, 2014
498
Spokane, WA
Do you ever use the winch? Install a front receiver hitch for the winch to mount to when you need it & cut the bumper up for more air flow
Hoffie
Mar 10, 2015
212
The winch mount is a bolt on to the frame style and if taken off leaves a huge opening for air. I will have to look into how I can fab a receiver hitch into the opening. I am sure that it can be done.
Rudy1
Jul 6, 2016
55
Illinois
I know its pricie but i wouldnt cut anything and put a bigger radiator in. Im not sure if your truck is stock. But ive heard of alot of guys puttng bigger radiator in. Just saying
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
The stock trucks don't overheat. A bigger radiator is just a bandaid for poor airflow.
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
You can see the opening here before I installed the winch plate and winch.
that opening is allowing air to bypass the cooling stack. I cut my hole out and made a bigger rubber dam to shove the air towards the raditator. motor stays around 178-185 according to the autocal. trans is warmer again but the spin on filter is way past due
