3.42s in a Street Truck
prostreeter600
Street rodder
Jul 18, 2010
912
Dallas Tx
Bring back an old thread. Will going to 3.42 gears with my 30.2" tall DRs make my (empty)5660# truck go faster or slower in the 1/8 and 1/4 . My new triple setup pulls extremely hard and it hasn't even been tuned for the triples yet. Currently running on tunes for my last compound setup. So my guess is that the torque will load the motor and turbos harder and propel the truck a lot harder with the 3.42s . Plan is to take the truck out to the 1/8 mile track as soon as I put in my new Goerend LL converter, gather some data and then have Mark at DP build me some tunes for it . Then go back out to the 1/8 mile track for additional testing and data gathering. Hopefully somebody that has already done this and has personal information can chime in.
prostreeter600
Street rodder
Jul 18, 2010
912
Dallas Tx
Hoosier 325/45/18 Drag Radials . I plan on using them for the street and the track . I don't drive it much other than week ends . I DD a 2015 High Country 2500 . I had Nitto NT05s 305/45/18s on it but wanted the taller tires. The Hoosiers actually have a higher load rating . I know the Hoosiers are DOT rated for racing class only so hopefully I won't catch too much trouble .
prostreeter600
Street rodder
Jul 18, 2010
912
Dallas Tx
The Nittos would do better I think for that . The Hoosiers are softer and will wear out sooner plus the Hoosiers are like slicks with small square block outs for gauging how much rubber is left is my best guess. The Nittos hooked up good on the street and track on my truck .
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I just picked up a set of mickey thompson et street R's in 305/45r18. Haven't put them on the truck yet but they market them as a drag radial that will hold up to street miles. They are weight rated to hold our trucks as well.
PACougar
2,105
El Dorado Hills, Ca
I'm definitely considering them. I wish they made a bit taller tire.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
That is a pretty short tire. 28.8" tall.
With stock gears and 30x14 slicks, going through the traps at 135mph put me around 4200rpm.
I'd have to think the 3.42's would more than make up for it though.
prostreeter600
Street rodder
Jul 18, 2010
912
Dallas Tx
So Mike, with the 30.2" tall tires (Hoosier DRs) do you think it would be beneficial to go 3.42s . I'm not sure what RPMs my motor will need to shift at with the 9100AF and the rest of my components . Judging by your numbers it sounds like 3.42s will be in order . How much does your truck weigh ?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I'd say you'll want to shift around 4000rpm. I have a baby stage 1 empire cam and I shift at 3700-3800 rpm. I tried 4000+ but it made zero difference, so I dropped it down. My truck is dead even at 7000lbs. If you plan to regularly run those tires, I'd say 3.42's would be wise. If it's a weekend only deal, I'd stick with stock gears. Only reason I haven't switched gears myself. I go to the track typically every 2nd or 3rd week.
prostreeter600
Street rodder
Jul 18, 2010
912
Dallas Tx
I think so too . It Revs very quick and pulls super hard . My current tunes are for the 6480SF and compounds I had before . I believe my shift points are at 3800 currently .once I get the new converter in it and find out what can stall it to . I'm gonna have Mark tune it for me . It's a pricey change on the gears same as everything else on our trucks so I'm trying to see if others have already done it with good results
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
Update: Every 5 speed truck making more than stock power should have 3.42s. It spends more time in each gear so the trans seems happier and isn't shifting so much, it pulls much smoother, and it dropped the rpms a bunch on the highway which killed the exhaust drone and generally makes my pants tight. DO IT.
