1/4 mile discussion and time slips post here!
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
Madras, OR, Pahrump NV
Jeff Moore just got a new personal best with his new setup! Truck is an lbz ccsb 4x4 and weights 6800lbs. Has 150% S&S injectors and Exergy 12mm cp3, Danville 72mmStg2R1Vgt fed by a pair of Borg S369's in a triple kit we made for him. I tune this truck also. These passes were on tune4. Need to have Evan@LimitlessDiesel do the trany so it will get the job done right! Very happy with it for first passes out with this setup.:thumb:
Congratulations, will post up after the weekend in case there are more entries. :thumb:
2DMAX
Feb 27, 2014
It felt good on tune 4. Have to solder the connections on the lockup box for sure.
Trans was a little pissed on 2nd run but still going! Help the trans out a little and will push this thing and see what it can do.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Congrats!!
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
1.NGM Diesel Dragster 7.02 @ 195.48 (9-4-15) - 2050 lbs, Turbo 400, Johnboy
2.Banks Dragster 7.170 @ 181.08 (4-30-09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
3.NGM Diesel Prostock 7.44 @ 187.55 (6-1-13) - 2800 lbs, Turbo 400 - Johnboy
4.Batmobile prostock 7.469 @ 185.41 (6-4-16) - 2700 lbs, LBZ, Bruno/Lenco - Vollmer
5.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
6.Banks Sidewinder Type-D Prostock 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
7.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
8.John Sleath, (UK) S-10 Prostock 8.3664 @ 167.30 (10-31-15) - 3350 lbs, LB7, 4L80E - Sleath
9.Comp461 dragster 8.508 @ 161.05 (10-4-14) - 1965 lbs, Powerglide/Gearvendors - C. Byden
10.bcdeutch731 C-10 8.556 @ 161.67 (11-1-15) - 4610 lbs, LLY, T-400, 2x4 - DP
11.Dirtymax prostock 8.63 (6-16-12) @ 158.23 (5-19-12) - 3268 lbs, LB7, Lenco - ATP
12.RPM Motorsports 73 Nova 8.902 (5-28-16) @ 155.49 (6-6-15) - 3460 lbs, LBZ XP 5 Glide, ATP
13.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
14.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
15.Trippplemax #1, Ill Tempered 9.24 (9-12-15) @150.20 (5-30-15) - 6005 lbs, LBZ Stroker, Durflite - C. Buhidar
16.Max'd Out 9.360 (10-15-11) @ 154.40 (5-5-16) - 6050 lbs, LBZ, Duraflite - ATP
17.K Douglas C-10 9.393 @ 147.46 (10-4-14) - 3100 lbs, LBZ - 2x4 - G&J
18.J Hyatt 9.458 (5/5/16) @ 150.78 (4-23-16) - 6300 lbs, LB7 - T Martino
19.Trippplemax #2, Road Rage 9.459 @ 146.45 (8-8-15) - 5950 lbs, LBZ, stroker, Duraflite, C. Buhidar
20.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - 5950 lbs, LB7 - Dmitri
21.Merchant's Sandrail 9.62 @ 138.90 (6-27-15) - 2000 lbs, LBZ - Dmax Tuner
22.Industrial Injection shop truck 9.638 @ 154.99 (8-22-15)- 6040 lbs LB7 - Duraflite, Starlite
23.SmoknDmax05 9.655 @ 140.23 (5-7-16) - 5750 lbs, LLY - Duraflite, Fleece
24.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
25.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
26.cafryer 9.769 @ 145.02 (8-16-14) - 6500 lbs, LB7 - Duraflite- Starlite
27.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
28.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
29.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
30.Orange Crush 9.875 @ 139.41 (9-25-07) - LB7, 2x4 - TTS
31.Dmax02 9.893 @ 139.62 (6-10-16) - 6160 lbs, LLY, MarkBroviak
32.Mika (FIN) 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
33.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
34.IBDMAX'IN "Skeeter" 9.924 @ 145.23 (6-416) 6280 lbs LB7- 2x4 - Wade Boyd
35.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
36.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
37.Dmax Tuner 9.995 @ 138.89 (10-8-15) - 5500 lbs, LB7 - Dmax Tuner
38.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
39.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
40.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
41.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
42.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
43.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
44.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
45.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
46.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
47.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
48.Harbin_22 10.419 @132.95 (6-10-16) - 6860 lbs, LMM - MarkBroviak
49.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
50.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
51.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
52.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
53.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
54.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
55.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
56.Hondarider552 10.578 @ 133.88 (4-6-14) - 5400 lbs, LB7- PPEI
57.Meshanic 1/2 ton 10.5816 @ 133.97 (11-14-15) - 5400 lbs, LLY - Meshanic
58.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
59.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
60.White Devil 10.672 @ 132.62 (4-24-15) - ?, LLY - CaptPhil
61.2themax2 10.687 @ 129.06 (5-21-16) - 6700lbs, LMM - Starlite
62.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
63. IBDMAX'IN "Blue Angel" 10.71X @ 131.XX (2009) LB7 -Wade Boyd
64.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
65.Mike Diesel 10.725 @ 134.97 (4-23-16) - 7000 lbs, LLY - Starlite
66.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
67.2DMAX 10.768 @ 132.02 (6-17-16) - 6800 lbs, LBZ - MarkBroviak
68.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
69.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
70.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
71.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
72.Maine04max 10.825 @ 128.73 (10-3-15) - 6920 lbs, LB7 - Main04max
73.NLDP 10.85 @ 123.35 (6-24-06) - 6300 lbs, LB7 - TTS
74.The Dumpster Van 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - JoshH
75.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
76.Scott Mathews 10.9022 @ 127.44 (11-7-15) - 6800 lbs, LLY- Diesel Addiction
77.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
78.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
79.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
80.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
81.Joegorby 10.984 @ 125.94 (8-14-15) 6750 lbs, LMM - PPEI
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
1.NGM Diesel Dragster 6.997 (7-9-16) @ 195.48 (9-4-15) - 2050 lbs, Turbo 400, Johnboy
__________________
3,419
Have to give Wade credit. He might be a complete pain in the ass, but when he says he's going to do something, he does it.
Congrats to him and his crew.
Secondly, Johnboy sure turned into a heck of a tuner, didnt he?
Noreaster
2,910
Cape Cod,MA
Atleast Wade gets it done on the track, just the opposite of the jackstand racer from Texas
I saw on FB that Kory helped with the tuning
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
12.RPM Motorsports 73 Nova 8.640 @ 166.17 (7-23-16) - 3460 lbs, LBZ XP 5 Glide, ATP
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
39.THduramax 10.111 @ 136.36 (7-24-16) - 6000 lbs, LBZ, Duraflite - Fleece
40.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
41.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
42.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
43.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
44.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
45.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
46.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
47.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
48.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
49.Harbin_22 10.419 @132.95 (6-10-16) - 6860 lbs, LMM - MarkBroviak
50.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
51.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
52.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
53.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
54.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
55.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
56.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
57.Hondarider552 10.578 @ 133.88 (4-6-14) - 5400 lbs, LB7- PPEI
58.Meshanic 1/2 ton 10.5816 @ 133.97 (11-14-15) - 5400 lbs, LLY - Meshanic
59.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
60.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
61.White Devil 10.672 @ 132.62 (4-24-15) - ?, LLY - CaptPhil
62.2themax2 10.687 @ 129.06 (5-21-16) - 6700lbs, LMM - Starlite
63.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
64. IBDMAX'IN "Blue Angel" 10.71X @ 131.XX (2009) LB7 -Wade Boyd
65.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
66.Mike Diesel 10.725 @ 134.97 (4-23-16) - 7000 lbs, LLY - Starlite
67.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
68.2DMAX 10.768 @ 132.02 (6-17-16) - 6800 lbs, LBZ - MarkBroviak
69.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
70.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
71.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
72.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
73.Maine04max 10.825 @ 128.73 (10-3-15) - 6920 lbs, LB7 - Main04max
74.NLDP 10.85 @ 123.35 (6-24-06) - 6300 lbs, LB7 - TTS
75.The Dumpster Van 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - JoshH
76.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
77.Scott Mathews 10.9022 @ 127.44 (11-7-15) - 6800 lbs, LLY- Diesel Addiction
78.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
79.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
80.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
81.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
82.Joegorby 10.984 @ 125.94 (8-14-15) 6750 lbs, LMM - PPEI
Subman
Old Geezer
Jun 27, 2008
3,233
10
81
4.Batmobile prostock 7.469 @ 186.26 (8-6-16) - 2700 lbs, LBZ, Bruno/Lenco - Vollmer
13.Trippplemax #1, Ill Tempered 9.0063 @ 155.01 (8-6-16) - 6005 lbs, LBZ Stroker, Durflite - C. Buhidar
14.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
15.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
Wished I could have gone to see those runs today. Had to miss them and gonna miss the Big Sky event also.
Congrats to everyone on the fast times. Very impressive.
