front end upgrades
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
Mine has 223k on it, has moog tierods but was in a frontend wreck at about 200k or so and wondering how strong the center link is. Think both my arms need changed so i figured i would do it all at once. Which arms did u go with? And which braces?
All kind depends on what your gonna do with the truck and how much you want to spend. I did a full stage 3, so..centerlink, tie rods, pitman/idler braces, pivot, and gusset.
Way overkill, but that's what I wanted...most do just fine with sleeves and braces at higher Hp then I was
WVRigrat05
3,149
French Creek, West Virginia
I just did my truck, did HD pitman arm. And idler arm.
Don't do tie rod thinking they were bad. The pitman arm was shot with 5k on it.
So I not have everything built to the hilt and shits stop lol ****ed.
AJH
257
Memphis TN
Kryptonite Centerlink is strait...
I ran there stage 3 kit on my 05, like others have said its really only worth the cost if your going to rebuild everything on a high mileage truck, I had over 240k when I did mine, and man what a difference!!..low mileage trucks will be fine with sleeves and maybe the braces..imho
Here's a pic from when I did mine, for comparison
Yes it is but my understanding is that because the tierods mount back from the end of the centerlink it still doesn't give the same benefits of a true straight centerlink. Notice they also make the "race" centerlink.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
There is no f-ing way the kryptonite centerlink is going to flex... It may twist a bit on the steering arm and idler but it's not going to flex. If you have never had one or seen it in person, you don't fully understand how massive it is. I have a run stock with sleeves and braces, solid straight center link, and have the Krypotnite sitting in the garage waiting to go on. My hope is it will be the perfect blend of bullet proof and still have some sort of steering with out scrubbing the hell out of my tires.
AJH
257
Memphis TN
I've handled the full kryptonite front end (heavy sob). Also run sleeves previously this time I went with xd/dhd brace. I would still prefer a true straight centerlink. The cons of tire wear and tight turns aren't a concern. I burn through tires and back into parking spots.
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
Tire wear From a strait center link? Wasn't an issue for me if that's what your saying? I put 40k miles on it, half with37" inch then the rest with 305 toyo proxies.
As far as flex, I've got a go pro video somewhere of it after install launching 4 wheel...they don't flex
8,244
When you turn full lock with a straight center link that uses factory style inner tie rods, it cause bad scrub and will wear the outer edges of tires.
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
Ah, Ya I know what your saying..I could feel it but I don't think it was ever a problem..maybe because the 37"s were already scrubbing before the kit went on.
WVRigrat05
3,149
I worded it wrong, I mean it still puts pressure on the pitman and idler, I've never seen it on a lowered truck but I have on a leveled and it let the tires tow in more than my straight centerlink on my leveled truck.
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
so which pitman and idler arm do you guys recommend? see there are a few choices
Moog HD Idler arm K6535HD
Moog HD Pitman arm K6654HD
Super Steer SS175 idler support
Rare Parts Idler arm RP20608
Rare Parts Pitman arm RP20609
Rare Parts tie rods RP28559
Can't go wrong really with any if above choices
