Thats not exactly what I meant, but works just the same. :hehe:
Oh nope sure haven't :/ I mean the trans was built then blown up and then I replaced broken parts and left it exactly how it was when originally built just figuring I'm using pinion bearings from one trans and ring and sun gears from a different trans so I would guess the miss matching wear patterns may be it but honestly I don't know.
But sure looks pretty haha
:gayflag::gay:
:gayflag::gay:
Everyone says use dex3 on the 5spd yet gm says you can use dex6 to replace the dex3 what do you think about that ? Should dex3 be used with suncoast clutches ?
Dex 3, absolutely.
USE DEX 3!!!!
5 speed or 6 speed. Dex 6 is garbage.
What's the main reason for DEX VI being junk? Too slippery for the friction material?
What's weird is gm states dex6 is 100% improved with the fluids friction stability. I'm confused lol
Don't be. Listen to Mike.
Is Dex6 even an Allison approved fluid?
What do you consider severe application or usage? I daily drive mine but it's pretty fun to get on it. We talking under 10k or over 10k miles. Just curious what kind of service intervals would be good for the fluid to be swapped.^^^^^
Just remember that Dex 3 will need to be changed more often under severe usage as the addative package will burn away quicker. You may not be able to see this as the fluid will remain red and smell good, but it may not be doing its job.
