Noises 5spd under decel
Dvierra86
156
Awenta
4,090
They should cover it.
What are the 5 speed ones going for now? Should probably do that soon. Along with some lines that don't leak.
Mike L.
Got Sheep?
15,681
Fullerton CA
Everything was covered and paid for. Still doesn't help the fact that there are no 6 speed coolers for a while.:cry:
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I forgot to install the .100 shim on the p1 was the original noise concern. But just at idle in neutral or park trans is noisy. Not sure why
Yeah I understood the original noise was the lack of the spacer. I just assumed when you said it was fixed that you also found the source of the noise in park and neutral also.
Just curious. Glad it's up and going now.
Dvierra86
156
Oh nope sure haven't :/ I mean the trans was built then blown up and then I replaced broken parts and left it exactly how it was when originally built just figuring I'm using pinion bearings from one trans and ring and sun gears from a different trans so I would guess the miss matching wear patterns may be it but honestly I don't know.
But sure looks pretty haha
