Downpipe change out
Kilowatt39
Diesel Addict
May 10, 2016
17
SoCal
So this weekend, I plan on swapping my downpipe out with a MBRP. Any pointers with the LMM would be appreciated.
My LLY was pretty straightforward and I imagine that this will be as well, just a lot less room to work with.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Don't pull dipstick all the way out and cut heat shield in half . Makes it a lot easier.
Worked on mine, and I reinstalled it...
Jan 28, 2015
961
Ohio
I also put mine back in. On my lly you can wiggle it out in one piece but I had no luck doing that on my lmm. Not enough room to do that.
Kilowatt39
Diesel Addict
May 10, 2016
17
SoCal
Awesome, yea, on my LLY I just bent the crap outta the heat shield and it came right out. We will see how it goes tomorrow.:beer
Dallas S
496
Alberta
if your patient you can snake the dip stick out if you pry the bracket back abit and then you can leave the heatsheild on the downpipe and it cones out easily. i then cut the dipstick bracket so its just a single bolt design. works like a charm and once you have it figured out its actually quite easy on the lmm. i do cut the turbo heat sheild off aswell.
J_Stone06
Wasn't me...?
Oct 13, 2012
347
Nowhere, KS
Be patient..i took my dipstick all the way out and bloodied my knuckles putting it back in. That dang heatshield...:mad: That was the worst part of my exhaust swap.
WolfLMM
Making Chips
Nov 21, 2006
4,005
26
AL
Humm, I just grabbed the heat shield with vise grips, pulled and yanked on it till it came out:D
Kilowatt39
Diesel Addict
May 10, 2016
17
SoCal
I just ended up cutting it. I was tired of screwing with it and losing skin to random metallic parts of my truck.
