Allison 5sp: Friday the 13th
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Normally I don't believe in that crap but today everything g that could go wrong went wrong.
I decided to take my truck today instead of my motorcycle because I woke up with a migraine headache... That's where it started. Got halfway to work and knew I had to get fuel. Got fuel and grabbed lunch on the way to work, truck wouldn't go into reverse... Fluid was a quart low with no leaks since my driveway is spotless and nothing sprayed back under the truck. Walked 6 blocks in around 100* heat looking for ATF. Mother ****ing Chevy dealer doesn't carry Dex 3 because "Dex 6 is compatible with anything that takes Dex 3" I said **** you and walked out because that parts guy is a tool anyway. Fount Kendall Dex 3 at a pilot and walked back to my truck, was 45 mins late for work on an all overtime day and then had nothing but problems at work where nothing went right.
How was everyone else's Friday!
3,593
Nothing out of the ordinary. Typical 10.5 day, which is getting very old.
Did have a coolant leak start about 5pm, we think the Tstat stuck closed. Weird...never had that one happen before. Nursed the truck the last 40-ish miles (10 or so deliveries) under 45mph to keep temps down. Didnt want the mechanics have to make a road call.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Friday the 13th's aren't always bad, come to think of I never thought about it while driving 30 miles one way to wear this one last time.
:happy2:--------:happy2:--------:happy2:
Went to take nap around 4:00 PM yesterday and did not wake up till an hour ago.....
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
This was the first bad one for me, when things started out bad I should have stayed home but mandatory overtime said otherwise.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
WTF is that thing?
You asked...
Head/neck block that holds your head/neck in place for radiation treatment. See the black pins at the perimeter edge, they lock into the black table in the picture below. Ironic part of this whole deal, I have built 2 containment rooms/buildings, one back in about 2000 and the last one at Phoenix Cyberknife in 2012 where they also have a Varian True Beam like below...
Phoenix Cyberknife quantities for containment for the Varian Truebeam, Cyberknife and HDR.
1200 yards of concrete
80,000lbs steel plate
50,000lbs rebar
60,000lbs 99.99% pure lead
roxyfever
Feb 11, 2016
191
terrell tx
My explorer that im trying to get inspected and tuned up justvdecided to blow a tire sitting in the driveway yesterday. On top of that my wifes f350 had a blow out a few days before and it needs 4 tires an shocks. Just seems like i can never get caught up
rg3whitelbz
Jan 19, 2013
166
Maryland
Was at a standstill on I70 from 5-530am due to an accident then when I got to work and made coffee, the pot cracked wide open when I filled slightly tapped it filling my cup. Spooky
3,796
423
I normally get Fridays off, but I worked it to make up for taking Monday off. Place was very quiet, most people were home, so I got a lot of work done. Think I finally found all the coolant leaks on my truck, which is good. Still have to replace the heater core, though, which will suck majorly.
unionmax481
hot rodder
Aug 8, 2014
222
lebanon in
I had a great Friday the 13 my dad had to borrow my truck because his fuel pump went out on his truck. so on his way to get a load of pavers my truck started to shake and loose power and a shit ton of white smoke out the exhaust
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Was driving from California to Utah all day.
Went perfect actually. My jeep got the best mileage it has ever gotten, no flat tires, no check engine lights, no speeding tickets and I even made it home to a not burned down house an hour ahead of schedule.
8,244
I can say mine went well. Limo started right up and dropped baby girl off at daycare without an issue. Work actually went well for as busy as we are. Had lunch with my dad. Came home and watched "a nightmare on elms street" cause I was t about to test my luck with firing the truck up I'm building. Plus the fact it was 104* outside at that point lol
