Wastegate
Djd085
Nov 13, 2014
13
What's the deal with an external wastegate on a duramax? If it sounds good on a Subaru, I can only image it on a truck.
Djd085
Nov 13, 2014
13
The waste gate on the turbo opens and lets exhaust gas bypass the turbine, and back into the downpipe. Is this not the same in duramax-land?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
How will you hear it if it just reverts back to the down pipe..? All it will sound like is exhaust noise?? Confused
Djd085
Nov 13, 2014
13
I've owned an STi and wrx before this duramax.
Djd085
Nov 13, 2014
13
Stock is internal wastegate, I'm asking if anyone does external wastegates.
Djd085
Nov 13, 2014
13
Well in my STi an external wastegate fixed boost spike and held constant psi. With the stock internal wastegate, it was too small and caused it to over boost.
moparkxracer
2,309
33
Out and about
I have 3 external gates, I can't hear them. They plumb back into exhaust.
picture.php
Djd085
Nov 13, 2014
13
I didn't know if it was beneficial. Don't hate on the new guy.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Diesel doesnt really care about boost spikes. We don't "go lean" from it. The gate on a diesel is mainly to keep the turbo in its map and to relieve excess drive pressure.
Djd085
Nov 13, 2014
13
Makes sense. Thanks a lot! Subarus go real lean.
4,956
I suggest you don't turn your boost higher than 32psi OP. Beyond that you will blow that turbo.
