My new ppe stage 5 trans is throwing codes, im at work and forgot to write down the codes. But i remember a few were saying, fluid pressure sensor high voltage. Its also saying range shift inhibited. It also will engage into gear sometimes other times its like the tc is slipping real bad, or no fluid pressure. And it will also work in reverse sometime and the tires will roll forward in reverse. Any help would be appreciated. Im thinking its either the front pump or there is a wire loose in the valve body.
