lbz fprv shim
duramaxxx06
Aug 11, 2009
177
jasper tn
how do i do such? im ordering efi live from pat tomorrow and im sure this is something ill have to do? and whats the best place for a egt probe? do the kodiac drivers side manifold make a difference? thanks guys.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
Youll need to pick up the shim kit. Then basically you remove a 17mm bolt at the back of the fuel rail, disassemble that plug, add your shims, reassemble and replace.
Pat has done a write up on exactly how to do it in the HOW TO section. http://www.duramaxdiesels.com/forum/showthread.php?t=267
. Im sure he also has the shim kits available - pick one up the same time you order EFI LIVE.
If not, I have them in stock.
ripmf666
15,123
14
47
Wentzville Mo
18mm
13,598
632
I would recommend you not shim it unless you know it is blowing open. There is a chance you could actually screw something up by trying to fix something that isn't broke.
