LB7 Intake Heater
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
I was working on the motor yesterday swapping exhaust housings. I pulled the Intake heater coil out to ease the removal of the compressor cover.
Man is that coil big and takes up quite a bit or room in the intake horn. Looks to be quite a restriction also.
Anyone thought of deleting this? In a warmer climate I would think that it doesnt cycle very often and the glowplugs would sufficient for cold days.
Any thoughts?
280
Any thoughts?
yep i did while ago early 07.. cut all the coil elements off then stuck it back in there.. left the ~1/8" rod going down the center.. either way it is better then the ~1" coil that is oem there
used EFI live to turn off the intake heater permantly i put all tables to 0
the coldest i have started up is ~48* with no problem.
you can also control start-up time the GP are on (b0401)
and the engine running time the GPs are one (b0402) value is seconds of time the GP are on
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Travis you want the plug?:D
lots of people remove it,LLY dont even have a intake heater
you can use EFI to disable the coil and just remember to wrap the wire up in electrical tape.....there is a lot of voltage to that wire
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
Anyone know what, were, or how much $ for a plug? I'd like to keep my heater as a working part. Pipe plug from hardware store?
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Mines gone too. Looks like it could be a sizeable restriction. Don't know what the effect would be on a 0 degree morning. BTW doesn't the LLY use the EGR to take place of the LB7 heater?
jimdmax
Feb 18, 2007
264
Garden Prairie IL.
I Brought A Plug From Dmaxlover I Think He Makes Them ,you May Have To Pm Him But I Dont Think He Is On Here, May Have To Log On To Tdp And See If He Has Any. I Could Not Beleave How Big The Heating Elment Is. Let Me Know If You Can't Find Him.
Jim
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
Jim
That is who i got mine from,But i dont need it anymore
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
I took off all my egr equipment last summer, I didnt have any problems this winter.
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
Any thoughts?
I've got some extra plugs if you want one;)
Nasty Girl
Apr 11, 2008
55
Got rid of mine a couple years back for obvious reasons.:rofl: No problems at all even up here in our cold winters.
C.A.P
Feb 16, 2008
103
I have seen one person use the plug as a place to tap for boost measurement !
