I been dreaming about a engine build for my 71 C10 build and I am looking for some insight on a build recipe. My goals are for a lot of RPM(6000-7000RPM) with a good power curve and maybe a 500-600 HP and less then a 1000LBS of torque so i can make a T56 or a gas automatic transmission live, since this would be a diesel living in a gas engine world.
The build i am planing for is:
Cast Oval bowl Pistons
9100 AF cam
Internal balanced and lighted crank(if possible)
Aluminum rods
Billet main caps
Maybe a girdle(If needed)
High flow intake bridge
100 Over injectors(maybe Bigger)
Duel Pumps
High flow oil pump or dry sump pan
External oil filter and coolers
Stock ported LB7 heads( maybe a set of Wagler head if I feel rich)
Valve Springs
Push Rods
625 head Studs
Main studs
Is there anything you guys can recommend to add to this list? This isn't happening next week but maybe next year, but I am trying to keep a budget in mind. I know that i could build a gas engine for less that would do the same thing, but diesel fuel has gotten into my blood and I am sunk. I hope I am not insane with this goal.
9100 AF cam
Aluminum rods
Billet main caps
Duel Pumps
Valve Springs
Push Rods
625 head Studs
Main studs
