How does one go about adjusting a known, tested tune for larger injectors? I've been told that timing is one thing that kills motors, and by installing larger injectors, you can adjust the timing down and help save the motor. Obviously, if you get HUGE power, you might break someting, but it seems like the motor is more likely to survive at say 500RWHP with larger injectors and less timing and PW than huge PW and timing. At the moment, I'm not planning to go that route, although if having the nozzles honed is not too expensive and it actually can help extend the motor's live at say 500RWHP (when I figure out where my rail pressure is going, I should be near or over there) with timing and PW reduction, I probably would look into saving to have it done. I've also heard it said that a shorter pulsewidth will also help reduce EGT's which would be a BIG plus.
