Anyone know where I can find a temp sender that is the same range of resistance as the Allison trans fluid temp sensor/thermistor?
The allison sensor range is
141951 ohms at -45* C
2780 ohms at 25* C
37 ohms at 160* C
what I want to do is find a temp sender that is the same range as this, and use it as an engine oil temp sensor...then I could wire it in together with the allison trans temp sensor on a double throw switch.
so then I could flip the switch back and forth and see both trans temp and engine oil temp on the factory trans temp gauge in the instrument cluster.
that way I wouldnt have to add another external gauge, and I think it would be kinda clever to set it up this way. I mean if the oil temp gets above 250* or so I think the trans goes into "hot" mode, but then you can just flip it back and it will go back to normal.
any ideas?
thanks
ben
2780 ohms at 25* C
37 ohms at 160* C
any ideas?
thanks
ben
