LLY: HELP Limp mode after egr delete
1972chevy
Apr 21, 2013
27
I am trying to help out a friend of mine. His EGR cooler started leaking so he installed a sinister diesel EGR delete kit. The truck threw the usual EGR codes and went into a fuel limp (wont go over 2000rpm). I efi live tuned the truck shutting off the EGR codes hoping that would help but the truck was still in a limp with no codes. Has anyone had a similar issue or have any ideas what could be going on?
1972chevy
Apr 21, 2013
27
I disabled the egr, set the egm max/min temp and rpm perimeters to the mins/maxs and shut off the egr mils. It threw an egr closed performance code, another egr code I cant exactly recall off the top of my head and the owner said it threw a turbo under boost code that he cleared before I got to the truck but I was not able to get that code to come up again.
Robby05
Jul 25, 2014
498
Spokane, WA
Friend of mine had issues like that. I think he ended up leaving the EGR on and the set the min/max tables so it wouldn't call for EGR function. I'll ask him tomorrow what he did to remedy the issue
johnnygibs2
Mar 23, 2017
11
It's because u tune ur engine and now this is why ur having these problems
johnnygibs2
Mar 23, 2017
11
It's basically come down to this these engine are designed to handle a certain amount of pressure,psi ,torque and a tune allows u too bye pass that end give it more
johnnygibs2
Mar 23, 2017
11
And wen u put a tuner on it it's not under warranty because of the mod u put on ur engine
Awenta
4,090
CT
Thanks. Troll.
Your asshole was designed to do the shitting when you were born but it doesn't seem to be stopping your mouth from doing it either.
johnnygibs2
Mar 23, 2017
11
That the Reality of wha happens when u tune the problems are never going to end
TLyons90
Apr 22, 2013
1,631
Greenville, SC
To the OP have you tried un doing both batteries and letting it sit for about 30 mins and then plugging them back up and see what happens?
1972chevy
Apr 21, 2013
27
Apparently when your good for nothing you have to go around being an a** on the internet. Any way Thanks Robby. Be nice to hear what he did. I tried hooking the egr valve back up but still nothing. The truck was in a limp before I tuned it and went into the limp as soon as this guy started it after he installed his egr delete. I'm thinking it was something he missed or did on install of the delete. Correct me if I'm wrong but I dont think a truck with stock tuning will go into a limp just from an egr delete. Haven't tried unhooking the batteries but I cleared all the codes and flashed multiple tunes into the truck with no luck.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
You need to put a stock tune back in it and see what it's throwing for codes.
1972chevy
Apr 21, 2013
27
I did. All it threw was an egr closed performance code and I'm pretty sure the other one was an egr valve open circuit code
johnnygibs2
Mar 23, 2017
11
Why don't u take the egr value out and look at the passageway to check for any blockages and clean ur intake too . And check if there carbon on the value
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I've never seen an LLY in limp mode from EGR.
Very odd.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
It's been deleted dumbshit. Learn to read. And maybe to spell while your at it.
Better yet, lets play hide and seek, I'll hide, you count to a trillion and come find me.
4,948
Depends on the brand u got the delete from
Why are you here?
You can't read, you can't spell and you damn sure don't like tuning/performance. This forum is not for you. I suggest you take your bs ideals elsewhere
