Definitely easier to make lines shorter than longer for sureLol, nice!!!
Hey, if there a little long for a crew cab you could always shorthen them a bit...
Possibly, I've ran fair share of new brake lines on my stuff lolIf they made a tubing stretcher I'm sure you'd have one
Definitely a question worth askingWhat's the chances you could take the other 2 and have them made????
Hey if it saves you from haveing to make it, why not... they have the tools, materials, and equipment right there plus they get to add it to the library.Definitely a question worth asking
Just need to get a hold of person more knowledgeable at SS Tube who owns fine lineHey if it saves you from haveing to make it, why not... they have the tools, materials, and equipment right there plus they get to add it to the library.
Called Hicksville auto recycler (dmax only stuff) new used 6 port ABS pump is 225
Car part has 3 different ones listed..
Need to run RPO build code to see what I got..
I would have fought a lot hard with lines and cab in the way,Nice... I can't believe what the salt does to all that stuff...
