BD's down pipe sucks! This is the second one I have had that rattles! It is hitting my up pipes.
what is haywiremine rattled it just needed to be turned a bit
i used hay wire to pull it off the up-pipe
Bailing wire .............
I thought that was a ford thing:rofl: OMG
man they stopped using wire for hay and straw along time ago:spit:
Pat, I have a strap, it still rattles. I think* the SS housing on the HTT is shorter?? making the pipe closer to the up pipes.
They LB7 we built runs the HTT with the SS housing and the pipe is fine. We trimed the heads off some bolts on the firewall and made some small indents like they said to do in there booklet.
So what do you call it then?
maybe dimple the down pipe? Or twist it up a bit so its not resting on the up-pipe
did you wrap the pipe? that might help.
Well I hacked on the pipe some today. Cut the v flange off spaced it and re welded it. Paul would laugh at my welds they aren't pretty. I will check rattle levels tomorrow.
OT Henry, how do you take the plastic connectors off of the heater core lines? I snapped one while working on the "down" pipe :rofl:
