Let’s start from the beginning, I installed the stage 3 kryptonite front end and having a level kit on the truck I went and also bought the longer sway bar end links, just in case there were parts rubbing. The driver side hasn’t had any issues but the passenger side the end link bolt backed out and so I called kryptonite and they sent me bushings and bolts to repair the issue. I installed the bolt and made sure the bushing was starting to bulge out and gave it a little more just cause of the issue I had before. I have probably put 3K miles on the truck and the passenger side backed out again but this time broke off. Does anyone have any idea why this is happening. It’s on an 08 CCSB LLM with cognito upper control arms and leveling kit, so the torsion bars are a little raised just to gain 1/2 inch of bump stop clearance with 5100 bilstein shocks.
