Machining stock turbo
Dante2795
Looking at ideas before I go for it. I have a stock lly turbo with 10 blade turbine currently on my truck. Thinking of getting gt4094 68 compressor wheel and machining the cover out then getting balanced? Would that be a good set up? Also thinking about putting high flow vanes in as well. Let me know your opinions. Thanks
aashton1206
172
Just please make sure you disassemble the cartridge and send the center shaft with compressor/impeller wheels to Midwest to be balanced. And have fun, gonna be a great turbo
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
aashton1206
172
The shaft that connects the impeller and the turbine wheel
