how does one go about this? and how much should i go,or will be safe to lower? i have tie rod sleeves and clamped the front of my springs to cut down on wheel hop...need help with tips as i plan to goto the strip on the 26th
I took my bolts right out and put washers on them so i go to that same hieght everytime i also marked with a chisel and count the turns05_LLY said:Be sure to jack the truck up when adj, the bars so you dont take the chance of striping the bolt, plus its easier to turn!
i used a chisel to put a mark on the bolt and on the crosmember so as long as i remember how many turns i turned them i'm sure to get them back in the right spot!!!
sweetdiesel said:I took my bolts right out and put washers on them so i go to that same hieght everytime i also marked with a chisel and count the turns
also put antisieze on the bolts ive never jacked the truck but its probbally a good idea
just thinking about the jack, you could also use a 2 jaw gear pullerbrewmax said:good idea, i broke one off on a 01 that i used to have
